by snasui » Sat Sep 26, 2020 12:58 pm
Please attach the updated file and point to cell that shown incorrect result and fill in the correct value for that cell for easy to understand it.
sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
#22
by sna » Sat Sep 26, 2020 3:19 pm
Thanks for your kind ,I just highlighted the non matching value
by snasui » Sat Sep 26, 2020 4:07 pm
snasui wrote: Sat Sep 26, 2020 7:37 am
Adjust your formulas as below:
Q13
=IFERROR(INDEX('T24 INTRA'!N:N,MATCH(E13,'T24 INTRA'!$G:$G,0))+0,"")
Enter > Copy down
Please update column Q with my formula on above.
For the latest file in post #22, could you please explain how do you know the value in I23 and T23 is the same?
What the condition for convert the value in I13 (or T23)?
For now I think the formula in cell AB13 is:
=AND(F13=Q13,G13=R13,H13=S13,OR(I13=T13,I13*100=T13) ,J13=U13,ISNUMBER(SEARCH(V13*IF(R13="USD",4000,1),K13)),L13=W13,LEFT(M13,10)=LEFT(X13,10))
sna
#24
by sna » Sat Sep 26, 2020 10:26 pm
Hi Dear thank you but I have currency KHR,USD,THB
1USD=4000KHR,1THB=129.55 KHR
by snasui » Sat Sep 26, 2020 10:35 pm
You can adjust this part:
...V13*IF(R13="USD",4000,1)...
please try with yourself first.
sna
#26
by sna » Sun Sep 27, 2020 12:25 am
Ok thank you
sna
#27
by sna » Sun Oct 18, 2020 1:41 pm
I check it error date and rate base on my formula in intranet column AH and AJ.
What's wrong with the formula?
by snasui » Thu Oct 22, 2020 6:06 am
Please point to the error, provide the correct result, all condition you use and attach file again.
sna
#29
by sna » Thu Oct 22, 2020 12:11 pm
Here is attached file I check in sheet Reconcile Txn
by snasui » Sat Oct 24, 2020 12:01 am
Please read my post (#28) carefully.
sna
#31
by sna » Sat Oct 24, 2020 8:21 am
I put the test result in ReconcileTxn in column A
by snasui » Sat Oct 24, 2020 8:41 am
You can add
+0 for convert date as text to date as number in old formula in column 'E' as below:
=IFERROR(INDEX(INTRANET!AH:AH,MATCH(ROW()-12,INTRANET!$AG:$AG,0))+0 ,"")
Enter > Copy down.
sna
#33
by sna » Sat Oct 24, 2020 10:31 am
Thank you
sna
#34
by sna » Sat Oct 24, 2020 10:35 am
No luck ,see attached file
by snasui » Sat Oct 24, 2020 11:22 am
Please check regional and language on your machine, the format of date must be
dd/mm /yyyy not
mm/dd /yyyy.
Or change the formula on C13 with this,
=IFERROR(TEXT( INDEX(INTRANET!AH:AH,MATCH(ROW()-12,INTRANET!$AG:$AG,0)),"m/d/yy") +0,"")
Enter > Copy down.
sna
#36
by sna » Mon Oct 26, 2020 9:42 am
Thank you
