textbox content to cells merge
sna
Excel Ver: Excel 365
Post by sna »
Hi Dear!
Hopefully You're all doing fine.I need to transfer data from textbox to merge cells.the cells not having merge but when I run code cell itself should merge with value from Textbox1.
I create a code but when click button nothing happened
Dim BottomA As Long,i As Long
With Sheets("Sheet1")
BottomA=.Range("a"&Rows.Count).End(xlUp).Row
For i=2 To BottomA Step 2
.Range("a"&i &":a"&i+1).Merge
.Range("a"&i).MergeArea.Value=Me.TextBox1.Value
Next
End with
I wait for your kind response
Thank you in advance
Re: textbox content to cells merge
Try
BottomA=.Range("a"&Rows.Count).End(xlUp).Row+2
sna
Post by sna »
Thanks but I need that if I type hi it will merge a2:a3 ,I type hello a4:a5, good a6:a7 and so on
Thanks
Sample code
With Sheets("KONTRAK")
bottomA = .Range("A" & Rows.Count).End(xlUp).Row + 2
If .Range("a2").Value = "" Then
.Range("a2:a3").Merge
.Range("a2").Value = Me.TextBox1.Text
For i = 2 To bottomA Step 2
.Range("a" & i & ":a" & i + 1).Merge
.Range("a" & bottomA).Value = Me.TextBox1.Text
Me.TextBox1.Text = ""
sna
Post by sna »
Thank you
sna
Post by sna »
I have turn code to the below.i try to start merge at a2 but no luck
here's my code,how to fix it
Sub test()
With Sheets ("Sheet1")
n=BottomA
. Range ("a"&i+2 & ":a"&i+3).Merge
. Range ("a"&i+2).MergeArea.Value=Me.TextBox1.Text
Thanks
Sample the code post#4 already merge at A2:A3.
What's the problem with the original code?
sna
Post by sna »
It is not working fine
sna
Post by sna »
The code wrong typo should be but it isn't starting in a2
Sub test()
i=BottomA
sna
Post by sna »
Thanks puriwutpokin
I forget add 2 to bottomA
Now it is working fine...
Thank you 🙏
