doing average
sna
Excel Ver: Excel 365
doing average
Post by sna »
Hi Dear!
I have written a macro in form of custom function to average cells base on red color font.
I checked code right but why not calculate right?
Function AverageRed(rng As Range)
  Dim C As Range
  Dim Count As Long
  Dim Result As Double
  For Each C In rng
    If C.Font.ColorIndex=3 And IsNumeric(C.Value) Then
        Result = Result + C.Value
        Count = Count + 1
    Next
  If Count = 0 Then
    AverageRed = ""
    AverageRed = Result / Count
End Function
What's wrong ,any matter will share file
Best Wishes,
Re: doing average
:D Please attach the example Excel file with code above inside.
sna
Re: doing average
Post by sna »
Here's an attached
the first calculation is right but when change font to black it is not working well
Best Wishes,
Re: doing average
:D Your attached file is incorrect file type. The extension should be .xlsm instead .xlsx.
Changing the font color does not trigger your formula. Please see this link for more information. https://stackoverflow.com/questions/563 ... th-changes
sna
Re: doing average
Post by sna »
Ok thanks for the link
I will take a look
Best Wishes,
sna
Re: doing average
Post by sna »
File attached
