Get 2 dates
sna
Excel Ver: Excel 365
Get 2 dates
Post by sna »
Hi Dear,
I need your help how to split two dates range to column wise.
I attached a template
Thanks
norkaz
Excel Ver: 2013,365
Re: Get 2 dates
Post by norkaz »
B2
=LEFT(A2,SEARCH("-",A2)-1)&RIGHT(A2,5)
C2
=LEFT(A2,SEARCH(" ",SUBSTITUTE(A2,"."," ")))&MID(A2,SEARCH("-",A2)+1,99)
Norkaz
sna
Re: Get 2 dates
Post by sna »
Hi
Thanks for your answer but the date is not real date is just a text,I can't do calculation
norkaz
Excel Ver: 2013,365
Re: Get 2 dates
Post by norkaz »
Hi Guy,
The answers were exactly provided by referring to the sample in your attached template #1.
However: refer to #3
B2
=LEFT(A2,3)&"/"&MID(SUBSTITUTE(LEFT(A2,SEARCH("-",A2)-1),"."," "),SEARCH(" ",SUBSTITUTE(A2,"."," "))+1,3)&"/"&RIGHT(A2,4)
C2
=LEFT(A2,3)&"/"&SUBSTITUTE(MID(A2,SEARCH("-",A2)+1,9),",","/")
In case cannot do the calculation or it doesn't work between column B and Column C, please change both formulas to values by copy and paste special "VALUES" in both columns.
Then select B2:B5 -> Data Text to columns -> Next -> Next -> at the Date option, at the drop-down select MDY then Finish.
Then do the same way at C2:C5.
Norkaz
sna
Re: Get 2 dates
Post by sna »
Thanks
