Week
sna
Excel Ver: Excel 365
Week
Post by sna »
Hi Dear,
I need your help how to get the results as in column B.i used the weeknum function but it is no luck.
I also attached a sample
Thank
norkaz
Excel Ver: 2013,365
Re: Week
Post by norkaz »
B2
=INT(ROWS(B$2:B7)/6)
Norkaz
sna
Re: Week
Post by sna »
thank you but another choice could it work with weeknum function?
norkaz
Excel Ver: 2013,365
Re: Week
Post by norkaz »
Hi Guy
As far as we know the weeknum function returns the number of each week.
Refer to your data that shows 6 days per week and skips the Sundays. If your data pattern is always like that, the formula at B2 should be...
B2
=WEEKNUM(A2)-WEEKNUM($A$2)+1
Norkaz
sna
Re: Week
Post by sna »
Thank you 😊
