code help
sna
Excel Ver: Excel 365
code help
Post by sna »
Hi dear
I have this 2 sheets where in the expected purchases sheet row2, I got the values with the help of formulas connected to the already existing 2 sheets. I need your expertise to convert the formulas into code and get the data in Purchases sheet. The code to create the purchases sheet with headings is working.
with the help of a code, insert formulas in each column as shown in the purchases sheet row2
resize the data in Purchases with 2B
The new created purchases sheet should match the expected result as shown without the formulas.
Thank you in advance.
sna
Re: code help
Post by sna »
Cancel
sna
Re: code help
Post by sna »
Hi there,
Please skip above question,I asked for advice on VBA. Actions to do 1. Separate the data in the L line into Room# and the last name in the M and N lines. 2. Rearrange the sheet "Working" data in the Sheet"MOVECOLUMN" Result: Just press one system and you can do it To the above action question 1 How can I use vba to write the formulas of m and n lines, and then automatically run to the last line with data 2 How to change the formulas to the value in vba in the m and n lines
sna
Re: code help
Post by sna »
here is a template
learning.xlsm
(32.02 KiB) Downloaded 103 times
sna
Re: code help
Post by sna »
Hi there,
I need your help how to split text
Sub SplitText()
    Range("m3").Select
     Do While ActiveCell.Offset(0, -1) <> ""
        ActiveCell = Mid(Split(ActiveCell.Offset(0, -1), "/")(0), 3, 99)
        ActiveCell.Offset(0, 1) = Split(ActiveCell.Offset(0, -1), "/")(1)
        ActiveCell.Offset(1, 0).Range("A1").Select
I don't want to loop like this
Re: code help
:D The example code is below:
Sub SplitTextAndRearrangeCols()
    Dim rall As Range, r As Range
    Dim rw As Long
    With Worksheets("working")
        Set rall = .Range("l3", .Range("l" & .Rows.Count).End(xlUp))
        rw = rall.Rows.Count
        For Each r In rall
            r.Offset(0, 1).Resize(1, 2).Value = VBA.Split(VBA.Replace(r.Value, "Rm", ""), "/")
        With Worksheets("movecloumn")
            .Range("a2").Resize(rw).Value = rall.Parent.Range("b3").Resize(rw).Value
            .Range("b2").Resize(rw).Value = rall.Parent.Range("g3").Resize(rw).Value
            .Range("d2").Resize(rw).Value = rall.Parent.Range("c3").Resize(rw).Value
            .Range("e2").Resize(rw).Value = rall.Parent.Range("m3").Resize(rw).Value
            .Range("g2").Resize(rw).Value = rall.Parent.Range("n3").Resize(rw).Value
sna
Re: code help
Post by sna »
Thank you, always awesome 😊
