Please provide all steps for testing, what value in each cell and what button has error and what the result if don't any error. You should post the picture of error for easy for verifying.
Hi
It does not show up error.I search by ID if I type 1 it shows the data when click button search and amend data click edit it edit in sheet database but when I type 2 in ID (C5) it doesn't show anything when click search or edit.
For n = 2 To x + 1
If Sheet2.Range("a" & n) = Sheet1.Range("c5") Then
Sheet1.Range("c7") = Sheet2.Range("b" & n)
Sheet1.Range("c9") = Sheet2.Range("c" & n)
Sheet1.Range("c11") = Sheet2.Range("d" & n)
Sheet1.Range("f5") = Sheet2.Range("e" & n)
Sheet1.Range("f7") = Sheet2.Range("f" & n)
Exit For
Next n
x = Sheet2.Range("a:a").Count
n = Sheet2.Range("a" & x).End(xlUp).Row + 1
For i = 1 To n
If Sheet2.Range("a" & n) = Sheet2.Range("a" & i) Then
Sheet2.Range("a" & n & "f:" & n).ClearContents
MsgBox "ID dup"
If Application.CountIfs(Sheet2.Range("a2:a" & n), _
Sheet1.Range("c5").Value) Then
MsgBox "ID dup"
For i = 1 To n
' If Sheet2.Range("a" & n) = Sheet2.Range("a" & i) Then
' Sheet2.Range("a" & n & "f:" & n).ClearContents
' MsgBox "ID dup"
' Exit Sub
'Else
Sheet2.Range("b" & n) = Sheet1.Range("c7")
Sheet2.Range("c" & n) = Sheet1.Range("c9")
Sheet2.Range("d" & n) = Sheet1.Range("c11")
Sheet2.Range("e" & n) = Sheet1.Range("f5")
Sheet2.Range("f" & n) = Sheet1.Range("f7")
' End If
