Excel query 2
sna
Excel Ver: Excel 365
Excel query 2
Post by sna »
Dear all ,
I need dynamic array to solve problem n get outputs as in attached
Thanks
Re: Excel query 2
:D Go ahead and give it a try.
=MAKEARRAY(ROWS(A2:A7),4,
   LAMBDA(r,c,
      LET(
         row, INDEX(A2:A7,r),
         countryRaw, TEXTBEFORE(row," ("),
         country, TEXTBEFORE(countryRaw," ",-1),
         utc, "UTC"&TEXTBEFORE(TEXTAFTER(row,"(UTC"),")"),
         latToken, TEXTAFTER(row,"LAT "),
         lat, IFERROR(TEXTBEFORE(latToken," "), latToken),
         longToken, TEXTAFTER(row,"LONG "),
         long, IFERROR(TEXTBEFORE(longToken," "), longToken),
         CHOOSE(c, country, utc, --lat, --long)
sna
Re: Excel query 2
Post by sna »
Can be without MAKEARRAY? Thk
sna
Re: Excel query 2
Post by sna »
Yes your formula works awesome, i try it but no luck
=LET(
a, A2:A7,
GETVAL, LAMBDA(m, --TEXTBEFORE(TEXTAFTER(a, m), IF({1,0}, " ", CHAR(10)))),
Country, TEXTBEFORE(TEXTBEFORE(a, " (", 1), " "),
t, TEXTAFTER(TEXTBEFORE(TEXTAFTER(a, "("), ")"), " "),
LAT, GETVAL("LAT "),
LONG, GETVAL("LONG "),
HSTACK(Country,t, LAT, LONG)
Re: Excel query 2
sna wrote: Sat Nov 15, 2025 9:57 pm Can be without MAKEARRAY? Thk
:D Try this,
=DROP(
   REDUCE("", A2:A7,
      LAMBDA(acc,row,
         LET(
            VSTACK(acc, HSTACK(country, utc, --lat, --long))
   1
sna
Re: Excel query 2
Post by sna »
Thanks you
