ตัวอย่าง Code ตามด้านล่างครับ
Sub test()
Dim prjs As Range, prj As Range, pjl As Integer
Dim pa As Range, paCheck As Range, pck As Range
Dim cmAll As Range, cm As Range, cmr As Range, c As Range
Dim grpAll As Range, gSl() As Variant, gc As Integer
Dim gt As Range, g As Range, iCount As Integer, i As Integer
Dim ig As Integer, t As String, x As String
With Sheets("Sheet2")
Set pa = .Range("a2", .Range("a" & .Rows.Count).End(xlUp))
Set grpAll = .Range("f1", .Range("f1").End(xlToRight))
With Sheets("Sheet3")
Set paCheck = .Range("a3", .Range("a" & .Rows.Count).End(xlUp))
For Each pck In paCheck
pjl = Application.Match(pck, pa, 0)
Set cmAll = pa.Offset(pjl - 1, 1).Resize(1, 2)
gc = Application.Match(pck.Offset(0, 1), grpAll, 0)
Set gt = Range(grpAll.Offset(1, gc - 1), grpAll.Offset(1, gc - 1) _
.End(xlDown)).Resize(, 1)
iCount = 0
For Each g In gt
If Application.CountIf(cmAll, g) = 0 Then
ReDim Preserve gSl(iCount)
gSl(iCount) = g
iCount = iCount + 1
Next g
Set cmr = pck.Offset(0, 2).Resize(1, 2)
t = ""
i = 0
For Each c In cmr
Do While i <= 1
x = gSl(Int(Rnd * (UBound(gSl) + 1)))
If InStr(t, x) = 0 Then
t = t & x
c.Offset(0, i) = x
i = i + 1
Next c
Next pck
