Private Sub cbPhase_Change()
Dim myCell As Range
Dim rngItems As Range
Set rngItems = Sheet6.ListObjects("tbAllChecklist").ListColumns(6).DataBodyRange.Value
Me.lbInitializeLeft.Clear
Me.lbInitializeRightClear
With Me.lbInitializeLeft
.LinkedCell = ""
.ListFillRange = ""
For Each myCell In rngItems.Cells
If Trim(myCell) <> "" Then
.AddItem myCell.Value
Next myCell
Me.lbInitializeLeft.MultiSelect = fmMultiSelectMulti
Me.lbInitializeRight.MultiSelect = fmMultiSelectMulti
Dim processCode As String
Set rngItems = Sheet6.ListObjects("tbAllChecklist").ListColumns(5).DataBodyRange
Me.lbInitializeRight.Clear
' .LinkedCell = ""
' .ListFillRange = ""
processCode = Application.WorksheetFunction.VLookup(cbProcess.Value, _
Sheet7.ListObjects("tbProcessName").Range, 2, False)
If Trim(myCell.Value) <> "" Then
If myCell.Offset(0, -4).Value = processCode And _
myCell.Offset(0, -2).Text = Me.cbPhase.Text Then
Next myCell
