time difference
sna
Excel Ver: Excel 365
time difference
Post by sna »
Hi dear,
I need your input how to calculate time difference between two time in a cell without use left and right function.
I also attached a template
Thanks
Re: time difference
sna wrote: Wed Oct 13, 2021 7:14 pm without use left and right function
:D What the problem of these functions?
sna
Re: time difference
Post by sna »
These functions working but my boss didn't need it
Re: time difference
:D I want your boss ask me by himself.
norkaz
Excel Ver: 2013,365
Re: time difference
Post by norkaz »
Hi Guy,
What's the reason that your boss doesn't need to use left and right functions?
Looks like it could have several functions/formulas to solve the problem like that.
Honestly, in that case, the functions still work then please let your boss uses simple functions such as left and right properly instead of finding out the difficult methods.
Norkaz
sna
Re: time difference
Post by sna »
thank you I try to explain him because I don't pretty much like complex formula
norkaz
Excel Ver: 2013,365
Re: time difference
Post by norkaz »
Another way, try this.
B2
=MID(A2,SEARCH("-",A2)+1,99)-MID(A2,1,SEARCH("-",A2)-1)
Norkaz
