Copy word table to excel
Posted: Thu Nov 19, 2020 10:25 pm
by sna
Hi Dear,
I need to copy from table word doc to excel .
I used this code form google but not working.
fine,I need to copy all table in word to a single sheet in excel.
I upload the file
Thanks
Re: Copy word table to excel
Posted: Thu Nov 19, 2020 10:55 pm
The example code is below:
With wdDoc
For t = 1 To .Tables.Count
Set xlWkSht = Sheets("Menu")
.Tables(t).Range.Copy
With xlWkSht
If .Range("a1").Value = "" Then
.Paste .Range("A1")
.Paste .Range("a" & .Rows.Count).End(xlUp).Offset(1, 0)
c = .UsedRange.Columns.Count
r = .UsedRange.Columns.Count
.Range("A1:" & .Cells(r, c).Address).WrapText = False
Next t
Posted: Fri Nov 20, 2020 8:23 am
by sna
I test the code it is working but not completely copied tables
Posted: Fri Nov 20, 2020 7:17 pm
Please post the correct result for easy to compare and fix VBA code.
Posted: Fri Nov 20, 2020 10:34 pm
by sna
I test it again it works but not fit column width
Posted: Fri Nov 20, 2020 10:45 pm
With xlWkSht
.Paste .Range("A1")
.Paste .Range("a" & Rows.Count).End(xlUp).Offset(1)
.UsedRange.WrapText = False
.UsedRange.EntireColumn.AutoFit
.UsedRange.EntireRow.AutoFit
Posted: Fri Nov 20, 2020 10:52 pm
by sna
Thank you
