Sub test_noti()
Call LineNotify("ทดลอง")
Call LineNotify("เทพ excel")
Sub LineNotify(msg As String, Optional stickID As Integer, Optional stickPack As Integer)
Dim LineToken As String
Dim lineMessage As String
Dim objectXML As Object
Dim URL As String
LineToken = "Your token"
'Line Message
yourMessage = msg
lineMessage = "message=" & yourMessage
Set objectXML = CreateObject("Microsoft.XMLHTTP")
URL = "https://notify-api.line.me/api/notify"
With objectXML
.Open "POST", URL, 0
.SetRequestHeader "Content-Type", "application/x-www-form-urlencoded"
.SetRequestHeader "Authorization", "Bearer " & LineToken
.send (lineMessage)
Debug.Print objectXML.responseText
Set objectXML = Nothing
ปรับ Procedure Sub LineNotify(msg As String, Optional stickID As Integer, Optional stickPack As Integer) โดยเพิ่ม Parameter ให้รับ Token เข้าไปด้วย เช่น Sub LineNotify(msg As String, tk as string, Optional stickID As Integer, Optional stickPack As Integer)
snasui wrote: Sun Jul 12, 2020 9:20 am ปรับ Procedure Sub LineNotify(msg As String, Optional stickID As Integer, Optional stickPack As Integer) โดยเพิ่ม Parameter ให้รับ Token เข้าไปด้วย เช่น Sub LineNotify(msg As String, tk as string, Optional stickID As Integer, Optional stickPack As Integer)
Sub test_noti()
Call LineNotify("ทดลอง", "P4KXtcORcFnpXuZKUZj6NUGPPSFvLMVtM8YzDf8RTqT")
Sub LineNotify(msg As String, tk As String)
Dim URL As String
'Line Notify Token ที่ Generate มา
LineToken = tk
'Line Message
yourMessage = msg
'เพิ่มเงื่อนไข Sticker
If stickPack = 0 Or stickID = 0 Then
lineMessage = lineMessage & "&stickerPackageId=" & stickPack & "&stickerId=" & stickID
With objectXML
.send (lineMessage)
Sub test_noti()
Call LineNotify("ทดลอง", "token 1", "token 2")
Sub LineNotify(msg As String, tk1 As String, tk2 As String)
Dim URL As String
LineToken = tk1
LineToken = tk2
'Line Message
yourMessage = msg
With objectXML
.send (lineMessage)
