Sum base on variable
sna
Excel Ver: Excel 365
Post by sna »
Hi there!
I have an issue with formula sum values base on month criteria.sum from the start month to month as variable.
In this example I sum base on Feb .it sums from Jan to Feb but the result not I need .it should 3 not 4.
TY
Re: Sum base on variable
I think you want the formula like this,
C5 =SUMIFS(OFFSET(A2,0,0,1,MATCH(B5,1:1,0)),OFFSET(A1,0,0,1,MATCH(B5,1:1,0)),"<>")
sna
Post by sna »
TY ☺️
