tPath = "C:\Users\THOMAS-611\OneDrive\สูตรExcel\address\" '<== Target path
For Each s In Sheets("Sheet1").Range("E1")
If Dir(tPath & s, vbDirectory) = vbNullString Then
MkDir "C:\Users\"
MkDir "C:\Users\THOMAS-611\"
MkDir "C:\Users\THOMAS-611\OneDrive\"
MkDir "C:\Users\THOMAS-611\OneDrive\สูตรExcel\"
MkDir "C:\Users\THOMAS-611\OneDrive\สูตรExcel\address\" & s
Sub Create()
Dim tPath As String
Dim s As Range
Dim sPath As String
Dim a As Variant
Dim b() As Variant
Dim p As String
'sPath = "D:\New Folder\" '<== Source path
tPath = "C:\Users\THOMAS-611\OneDrive\ÊÙµÃExcel\address\" '<== Target path
a = VBA.Split(tPath, "\")
For i = 0 To UBound(a)
ReDim Preserve b(i)
b(i) = a(i)
With Application
p = VBA.Join(.Transpose(.Transpose(.WorksheetFunction.Index(b, 0))), "\")
If Dir(p, vbDirectory) = vbNullString Then
MkDir p
' If Dir(tPath & s, vbDirectory) = vbNullString Then
' MkDir "C:\Users\"
' MkDir "C:\Users\THOMAS-611\"
' MkDir "C:\Users\THOMAS-611\OneDrive\"
' MkDir "C:\Users\THOMAS-611\OneDrive\ÊÙµÃExcel\"
' MkDir "C:\Users\THOMAS-611\OneDrive\ÊÙµÃExcel\address\" & s
' End If
FileCopy sPath & s.Offset(0, -3), tPath & s & "\" & s.Offset(0, -3)
Next s
Sub Create()
Dim tPath As String
Dim s As Range
Dim sPath As String
Dim a As Variant
Dim b() As Variant
Dim p As String
ReDim Preserve b(i)
b(i) = a(i)
With Application
MkDir p
' MkDir "C:\Users\"
' End If
Next s
Sub Create()
Dim tPath As String
Dim s As Range
Dim sPath As String
Dim a As Variant
Dim b() As Variant
Dim p As String
tPath = ThisWorkbook.Path & "\" & Sheets("Sheet1").Range("e1").Value '<== Target path
