Look up value same month from the table
sna
Excel Ver: Excel 365
Post by sna »
Hi there!
Greeting to everyone here!
My table is A1 to R12
When I input value in col T
Then I want the same value get in col u
TY
Xcelvba
Re: Look up value same month from the table
Post by Xcelvba »
You should to transpose the data with 2 column
=VLOOKUP(T2,$A$1:$B$108,2)
norkaz
Excel Ver: 2013,365
Post by norkaz »
U2
=IFERROR(INDEX($A$1:$R$12,AGGREGATE(15,6,ROW($A$1:$A$12)/(T2=$A$1:$R$12),1),AGGREGATE(15,6,COLUMN($A$1:$R$1)/(T2=$A$1:$R$12),1)+1),0)
Norkaz
sna
Post by sna »
It will not work if I changed to 1/02/2021....
norkaz
Excel Ver: 2013,365
Post by norkaz »
Please provide the Excel attached and the results that you expect.
Norkaz
sna
Post by sna »
TY,now it is Ok after correction of format
