Permutation
sna
Excel Ver: Excel 365
Permutation
Post by sna »
Hi Dear,
I have written a macro to create permutations .with combination of letters a,b,c...
Sub Permutation (num As Long)
Dim str As String
If num >= 1 Then
    For a = 97 To 122
        If num >= 2 Then
            For b = 197 To 122
                If num >= 3 Then
                    For c = 97 To 122
                        str = chr(a) & chr(b)& chr(c)
                        If Range("a1").Value = "" Then
                            Range("a1").Value = str
                            Range("a" & Rows.Count).End(xlUp).Offset(1, 0).Value = str
                    Next
            Next
            str =chr(a)
    Next
should I place it in a module like Call Permutation (5) ,right?
Thanks
Re: Permutation
:D Yes, you can call this procedure with other procedure by specify number as argument.
sna
Re: Permutation
Post by sna »
thank you 😊
sna
Re: Permutation
Post by sna »
I had given this to a friend
Sub MyMacro()
Call Permutation (4)
He said it was not working fine
Thanks
Re: Permutation
:D I don't think so. Please tell him to ask his problem in this place by himself.
sna
Re: Permutation
Post by sna »
Ok thanks 😊
