sna
Posts: 640 Joined: Tue May 05, 2020 8:18 am
Excel Ver: 2013,2016
by sna » Thu Apr 21, 2022 2:18 pm
Hi there,
I need formulas to compare two sheets with customer ID and LD .if it is different ,I need it to place it on Sheet "Check".if it is same ,keep it as it's.
I attach a sample as well.
thanks
norkaz
Posts: 1480 Joined: Wed Jan 12, 2011 7:59 pm
Excel Ver: 2013,365
by norkaz » Thu Apr 21, 2022 4:42 pm
A2
=IFERROR(INDEX('New Month'!A:A,AGGREGATE(15,6,ROW('New Month'!$A$2:$A$99)/ISNA(MATCH('New Month'!$A$2:$A$99&'New Month'!$B$2:$B$99,'Old Month'!$A$2:$A$99&'Old Month'!$B$2:$B$99,0)),ROWS(A$2:A2))),"")
Norkaz
sna
by sna » Wed Aug 17, 2022 9:23 pm
Thank you
