Sub FillCellsVertically()
Dim rng As Range
Dim cell As Range
Dim skipColors As Variant
Dim counter As Integer
' Define the range to check
Set rng = Range("A1:N20") ' Change this to your desired range
' Define the colors to skip (RGB color codes)
skipColors = Array(RGB(255, 165, 0), RGB(255, 192, 0)) ' Add more colors to skip as needed
' Set the counter to zero
counter = 0
' Loop through each cell in the range
For Each cell In rng
' Check if the cell has a fill color
If cell.Interior.Pattern <> xlNone Then
' Check if the fill color is not in the skip colors array
If Not IsInArray(cell.Interior.Color, skipColors) Then
' Increment the counter
counter = counter + 1
' Fill the current cell and the cells below it with the same color
cell.Resize(rng.Rows.count - cell.Row + 1).Interior.Color = cell.Interior.Color
Next cell
Function IsInArray(val As Variant, arr As Variant) As Boolean
Dim element As Variant
For Each element In arr
If val = element Then
IsInArray = True
Exit Function
Next element
IsInArray = False
End Function
Dim rng As Range
Dim cell As Range
' Check if the current row is a multiple of 8
If ((cell.Row + 1) - 1) Mod 8 = 0 Then
' Fill the current cell with orange color
cell.Interior.Color = RGB(255, 165, 0)
Next cell
