Sub CopyData()
Dim wb As Workbook
Set wb = Workbooks.Open("C:\Users\Desktop\Book1.xlsx")
With ThisWorkbook.Sheets("HO_TB")
' Copy data from "Sheet HO_ TB"
.Range("I6:J501").Value = .Range("F6:G501").Value
.Range("I503:J998").Value = .Range("F503:G998").Value
' Copy data from "Sheet MBR_ TB"
Sheets("MBR_TB").Range("I6:J501").Value = wb.Sheets("USD").Range("F6:G501").Value
Sheets("MBR_TB").Range("I503:J998").Value = wb.Sheets("KHR").Range("F6:G501").Value
' Copy data from "Sheet KHR" to "Sheet HO_TB"
wb.Sheets("USD").Range("F6:G501").Copy Destination:=.Range("I6:J501")
wb.Sheets("KHR").Range("F6:G501").Copy Destination:=.Range("I503:J998")
' Copy specific cells from "Sheet HO_TB"
.Range("I502").Copy Destination:=.Range("I291")
.Range("I999").Copy Destination:=.Range("I788")
' Copy values only
Sheets("MBR_TB").Range("I6:J501").Value = Sheets("MBR_TB").Range("I6:J501").Value
Sheets("MBR_TB").Range("I503:J998").Value = Sheets("MBR_TB").Range("I503:J998").Value
.Range("I502").Value = .Range("I502").Value
.Range("I999").Value = .Range("I999").Value
' Close the workbook
wb.Close SaveChanges:=False
Sub CopyData()
Dim wb As Workbook
Set wb = Workbooks.Open("C:\Users\Desktop\Working_TB.xlsx")
.Parent.Sheets("MBR_TB").Range("I6:J501").Value = wb.Sheets("USD").Range("F6:G501").Value
.Parent.Sheets("MBR_TB").Range("I503:J998").Value = wb.Sheets("KHR").Range("F6:G501").Value
' Copy values only
.Parent.Sheets("MBR_TB").Range("I6:J501").Value = .Parent.Sheets("MBR_TB").Range("I6:J501").Value
.Parent.Sheets("MBR_TB").Range("I503:J998").Value = .Parent.Sheets("MBR_TB").Range("I503:J998").Value
' Close the "Working_TB" workbook
The code works but this line .Range("I502").Copy Destination:=.Range("I291")
I mean cell I291=-I502
I788=-I999
Sorry for not clarifying of the problem.the code you gave it copied formula from I502 I291.I502 formula is deduct one cell from another.i want to refer I502 to I291 meant that I291=-I502 .hope it is clear.thanks
