copied formula
sna
Excel Ver: Excel 365
copied formula
Post by sna »
I need to copy previous month data to current month data base on S2 ,,,,,,,,,,,
Sub CopyData()
    Dim month As Date
    Dim colHeader As Range, currMonthCol As Range, prevMonthCol As Range, formulaCol As Range, valuesCol As Range
    ' Get the month selected in S2
    month = Range("S2").Value
    ' Look for the column with matching header for the previous month
    Set colHeader = Range("F5:Q5").Find(what:=Format(DateSerial(Year(month), Month(month) - 1, 1), "mmm-yy"), LookIn:=xlValues, LookAt:=xlWhole)
    If Not colHeader Is Nothing Then
        ' Set the range for the current month column
        Set currMonthCol = colHeader.Offset(1, 1).Resize(colHeader.End(xlDown).Row - colHeader.Row + 1, 1)
        ' Set the range for the previous month column
        Set prevMonthCol = colHeader.Offset(1, 0).Resize(currMonthCol.Rows.Count, 1)
        ' Copy and paste formula from previous month column to current month column
        prevMonthCol.Copy
        currMonthCol.Offset(0, -1).PasteSpecial xlPasteFormulas
        ' Copy and paste values from previous month column to current month column
        prevMonthCol.Copy
        currMonthCol.Offset(0, -1).PasteSpecial xlPasteValues
        Application.CutCopyMode = False ' Clear clipboard
        MsgBox "No column found for " & Format(month, "mmm-yy")
sna
Re: copied formula
Post by sna »
I want to copy previous data base on month in S2.if S2 is Sep-23 I like to copy column Aug-23 as formula to column Sep-23 .it means if S2 matches header F5:Q5 it will copy left column of it as formula and column on the left itself as values.....
Re: copied formula
:D The example code is below:
Sub CopyData()
    Dim month As Date
    Dim lstRw As Long
    Set colHeader = Range("F5:Q5").Find(what:=Format(DateSerial(Year(month), VBA.month(month), 1), "mmm-yy"), _
        With ActiveSheet
            lstRw = .Cells(.Rows.Count, colHeader.Column - 1).End(xlUp).Row
            Set currMonthCol = .Range(.Cells(colHeader.Row + 1, colHeader.Column), .Cells(lstRw, colHeader.Column))
            Set prevMonthCol = currMonthCol.Offset(0, -1)
            currMonthCol.Formula = prevMonthCol.Formula
            prevMonthCol.Value = prevMonthCol.Value
sna
Re: copied formula
Post by sna »
Thanks it works 👍
