Sub GetSheets()
Path = "D:\BOMfor\"
Filename = Dir(Path & "*.xls")
Do While Filename <> ""
Workbooks.Open Filename:=Path & Filename, ReadOnly:=True
For Each Sheet In ActiveWorkbook.Sheets
Sheet.Copy After:=ThisWorkbook.Sheets(1)
Next Sheet
Workbooks(Filename).Close
Filename = Dir()
Sub GetSheets()
Path = Sheets("list").Range("C2").Value
Filename = Sheets("list").Range("b2").Value
Next Sheet
Sub GetSheets()
With ThisWorkbook.Worksheets("REPORT")
Next Sheet
