หนูสร้าง UserForm เพื่อคีย์ข้อมูลต่างๆลงใน sheet ที่ต้องการ จากนั้นหนูได้ทำการแมป XML แต่ข้อมูลแรกที่บันทึกมันไม่อยู่ในตารางที่ได้แแมป XML และทำให้การรันลำดับรวนค่ะ
'Dim c1 As Range
'Dim ws1 As Worksheet
'Set ws1 = Worksheets("Datalist")
'For Each c1 In ws1.Range("ulname")
' With Me.ComboBox1
' .AddItem c1.Value
' .List(.ListCount - 1, 1) = c1.Offset(0, 1).Value
' End With
'Next c1
'Range("A2").Select
'Do While Not IsEmpty(ActiveCell.Value)
' ComboBox1.AddItem ActiveCell.Value
' ActiveCell.Offset(1, 0).Select
'Loop
Private Sub ButtonSave_Click()
Dim irow As Long
Dim iPart As Long
Dim ws As Worksheet
Sheet1.Activate
Set ws = Worksheets("¢éÍÁÙÅÊÙµÃ")
'find first empty row in database
irow = ws.Cells(Rows.Count, 1) _
.End(xlUp).Row
'iPart = Me.ComboBox1.ListIndex
'check for a part number
'copy the data to the database
With ws
.Cells(irow, 1).Value = Me.Label5.Caption
.Cells(irow, 2).Value = Me.ComboBox1.Value
.Cells(irow, 3).Value = Me.ComboBox2.Value
.Cells(irow, 4).Value = Me.TextBox1.Value
Range("A" & Rows.Count).End(xlUp).Select
Selection.ListObject.ListRows.Add AlwaysInsert:=True
Me.ButtonName.Enabled = True
Me.ButtonSave.Enabled = False
Me.ButtonClose.Enabled = True
Dim irow As Long
Dim iPart As Long
Dim ws As Worksheet
Worksheets(2).Activate
' irow = ws.Cells(Rows.Count, 1).End(xlUp).Offset(1, 0).Row
.End(xlUp).Row
With ws
With ws1
With Application
Dim casno As Range
Dim ulname As Range
.Cells(irow, 1).Value = Me.Label4.Caption
.Cells(irow, 5).Value = Me.ComboBox1.Value
.Cells(irow, 6).Value = Me.TextBox1.Value
.Cells(irow, 2).Value = .Index(ws1.Range("C2:C188"), .Match(.Cells(irow, 5), ws1.Range("D2:D188"), 0))
.Cells(irow, 3).Value = .Index(ws1.Range("B2:B188"), .Match(.Cells(irow, 5), ws1.Range("D2:D188"), 0))
.Cells(irow, 4).Value = .Index(ws1.Range("A2:A188"), .Match(.Cells(irow, 5), ws1.Range("D2:D188"), 0))
Range("F" & Rows.Count).End(xlUp).Select
