Sub sandorder()
Dim wb As Variant
Dim source As Range
Set sourceWb = ThisWorkbook
Set source = sourceWb.Sheets("Sheet1").Range("W1")
Set wb = Workbooks.Open("F:\DB\Production Control.xlsx", False, False)
i = wb.Worksheets("Dataromming").Range("B2:B6000").Find(source, LookIn:=xlValues).Row
source.Offset(0, 1).Copy
wb.Worksheets("Dataromming").Range("T" & i).PasteSpecial xlPasteValues
wb.Close True
Sheets("Sheet1").Unprotect ("410036")
If Worksheets("Sheet2").Range("A12:A33").Find(Range("B9"), LookIn:=xlValues) Is Nothing Then
MsgBox "กรุณาตรวจสอบรายการอีกครั้ง!"
Sheets("Sheet2").Unprotect ("410036")
i = Worksheets("Sheet2").Range("A12:A39").Find(Range("B9"), LookIn:=xlValues).Row
Worksheets("Sheet1").Range("N5:T5").Copy
Worksheets("Sheet2").Range("B" & i).PasteSpecial xlPasteValues, Transpose:=False
Application.CutCopyMode = True
Sheets("Sheet2").Protect ("410036")
i = Worksheets("Sheet1").Range("A12:A400").Find(Range("B6"), LookIn:=xlValues).Row
Worksheets("Sheet1").Rows(i).Delete
Range("B6,B9").ClearContents
Sheets("Sheet1").Protect ("410036")
Dim msheet
msheet = ActiveSheet.Name
With Worksheets(msheet)
.Protect password:="410036", DrawingObjects:=True, _
contents:=True, Scenarios:=True, _
userinterfaceonly:=True
.EnableAutoFilter = True
MsgBox "ทำรายการเรียบร้อยแล้ว"
Sub sandorder()
Dim SourceWb As Workbook
Dim Wb As Workbook
Dim rTarget As Range
Dim rSource As Range
Dim rRange As Range
Dim tRange As Range
Dim tSource As Range
Dim lngCount As Long
Dim lngLastRow As Long
Set SourceWb = ThisWorkbook
Set rTarget = SourceWb.Sheets("Sheet1").Range("W1")
Workbooks.Open ("C:\Users\bank9597\Downloads\Production Control.xlsx")
Set Wb = Workbooks("Production Control.xlsx")
lngCount = Wb.Sheets("Dataromming").Range("B" & Rows.Count).End(xlUp).Row
Set rSource = Wb.Sheets("Dataromming").Range("B2:B" & lngCount)
For Each rRange In rSource
If rRange = rTarget Then
rRange.Offset(0, 18) = rTarget.Offset(0, 1)
Next rRange
Wb.Close True
Set rSource = Nothing
Set rRange = Nothing
Set rTarget = Nothing
Set rTarget = SourceWb.Sheets("Sheet1").Range("B9")
lngCount = SourceWb.Sheets(1).Range("B" & Rows.Count).End(xlUp).Row
Set rSource = SourceWb.Sheets(1).Range("B12:B" & lngCount)
lngLastRow = SourceWb.Sheets(2).Range("A" & Rows.Count).End(xlUp).Row
Set tSource = SourceWb.Sheets(2).Range("A12:A" & lngLastRow)
For Each tRange In tSource
If tRange = rTarget Then
tRange.Offset(0, 1) = rRange.Offset(0, -1)
tRange.Offset(0, 2) = rRange.Offset(0, 2)
tRange.Offset(0, 3) = rRange.Offset(0, 4)
tRange.Offset(0, 4) = rRange.Offset(0, 5)
tRange.Offset(0, 5) = rRange.Offset(0, 6)
tRange.Offset(0, 6) = rRange.Offset(0, 9)
tRange.Offset(0, 7) = Now()
Next tRange
rRange.EntireRow.Delete
Next rRange
MsgBox "·Ó¡ÒÃÊÑè§ÂéÍÁàÃÕºÃéÍÂáÅéÇ"
Set tSource = Nothing
Set tRange = Nothing
Set Wb = Nothing
Set SourceWb = Nothing
