Sub Glass()
Dim last As Integer
Dim ir As Long
Sheets(1).Select
Range("B5").Select
Selection.Copy
Sheets.Add After:=Sheets(Sheets.Count)
ActiveSheet.Name = "Glass"
'Sheets("Glass").Select
[a1] = "Panel"
[a300].End(xlUp).Offset(1, 0).Select
:=False, Transpose:=False
Sheets(1).Select
Range("o16").Select
Selection.End(xlUp).Select
last = ActiveCell.Row
Range("O7:U" & last).Select
'Range("J7:M" & a).Select
Selection.Copy
'Sheets.Add After:=Sheets(Sheets.Count)
Range("B1").Select
ir = Range("a" & Rows.Count).End(xlUp).Row
For i = 1 To ir Step 1
If Range("a" & i) <> "" Then
[a300].End(xlUp).Copy
ActiveSheet.Paste
If Range("b" & i) <> "" Then
ActiveSheet.Paste
If Range("b" & i) = "" Then
'[a300].End(xlUp).Copy
[a300].End(xlUp).Delete
'sheet2
Sheets(2).Select
Range("B5").Select
Selection.Copy
Sheets(2).Select
Range("o16").Select
Range("O8:U" & last).Select
Selection.Copy
Range("B" & last).Select
[b100].End(xlUp).Offset(1, 0).Select
ActiveSheet.Paste
ActiveSheet.Paste
'sheet3
Sheets(3).Select
Range("B5").Select
Selection.Copy
Sheets(3).Select
Range("o16").Select
Selection.Copy
ActiveSheet.Paste
ActiveSheet.Paste
[i5].Select
'sheet4
Sheets(4).Select
Range("B5").Select
Selection.Copy
Sheets(4).Select
Range("o16").Select
Selection.Copy
ActiveSheet.Paste
ActiveSheet.Paste
'sheet5
Sheets(5).Select
Range("B5").Select
Selection.Copy
Sheets(5).Select
Range("o16").Select
Selection.Copy
ActiveSheet.Paste
ActiveSheet.Paste
'sheet6
Sheets(6).Select
Range("B5").Select
Selection.Copy
Sheets(6).Select
Range("o16").Select
Selection.Copy
ActiveSheet.Paste
ActiveSheet.Paste
'Sheet7
Sheets(7).Select
Range("B5").Select
Selection.Copy
Sheets(7).Select
Range("o16").Select
Selection.Copy
ActiveSheet.Paste
ActiveSheet.Paste
Columns("A:H").EntireColumn.AutoFit
Columns("C:D").Select
Selection.Delete Shift:=xlToLeft
Range("a300").Select
Range("A2:g" & last).Select
'Sheets("Glass").[a1].CurrentRegion.Select
'Rows("1" & last).Select
Selection.RowHeight = 18.75
With Selection
.HorizontalAlignment = xlGeneral
.VerticalAlignment = xlCenter
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
.MergeCells = False
Range("A1:F1").Select
Selection.Borders(xlDiagonalDown).LineStyle = xlNone
Selection.Borders(xlDiagonalUp).LineStyle = xlNone
With Selection.Borders(xlEdgeLeft)
.LineStyle = xlContinuous
.ColorIndex = xlAutomatic
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlEdgeTop)
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlEdgeBottom)
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlEdgeRight)
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlInsideVertical)
.TintAndShade = 0
.Weight = xlThin
With Selection.Borders(xlInsideHorizontal)
.TintAndShade = 0
.Weight = xlHairline
Columns("D:D").Select
Selection.Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
Range("D1").Select
ActiveCell.FormulaR1C1 = "Name"
Range("D2").Select
ActiveCell.FormulaR1C1 = "=RC[-3]&""""&RC[-2]&""""&RC[-1]"
Range("D3").Select
Range("D2").Select
Selection.AutoFill Destination:=Range("D2:D1000")
Range("D2:D1000").Select
Columns("D:D").EntireColumn.AutoFit
Rows("1:1").Select
Selection.Insert Shift:=xlDown, CopyOrigin:=xlFormatFromLeftOrAbove
'Sheets("Glass").[a2].CurrentRegion.Select
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
.ColorIndex = 0
.TintAndShade = 0
.Weight = xlThin
.ColorIndex = 0
.TintAndShade = 0
Range("A2:G2").Select
Selection.Font.Bold = True
พอรันแล้วจะได้หน้า Glass ค่ะ ตอนแรกไม่ทราบว่าจะมีชีทเพิ่ม เลยทำแบบใช้ลำดับชีทเลย ตอนนี้มีชีทเพิ่มเรื่อยๆ เลยต้องหาแนวทางการเขียนใหม่ค่ะ
