ลุ้นครับกลัวอาจารย์จะoffline
วางmsgBox ได้ผลครับ ขออนุญาติส่งคำสั่งทั้งคำสั่งนะครับ ซึ่งก็เป็นโมดูลที่ชื่อ Imdata แต่ชื่อ sub Re()
Sub Re()
Sheets("FileB").Activate
Columns("A:T").Select
Selection.ClearContents
Selection.QueryTable.Delete
With ActiveSheet.QueryTables.Add(Connection:=Array( _
"OLEDB;Provider=Microsoft.Jet.OLEDB.4.0;Password="""";User ID=Admin;Data Source=C:\Program Files\DumP\DATA\PALM.mdb;Mode=Share Deny Write" _
, _
";Extended Properties="""";Jet OLEDB:System database="""";Jet OLEDB:Registry Path="""";Jet OLEDB:Database Password="""";Jet OLEDB:Engine " _
, _
"Type=5;Jet OLEDB:Database Locking Mode=0;Jet OLEDB:Global Partial Bulk Ops=2;Jet OLEDB:Global Bulk Transactions=1;Jet OLEDB:New " _
, _
"Database Password="""";Jet OLEDB:Create System Database=False;Jet OLEDB:Encrypt Database=False;Jet OLEDB:Don't Copy Locale on Comp" _
, "act=False;Jet OLEDB:Compact Without Replica Repair=False;Jet OLEDB:SFP=False" _
), Destination:=Range("A1"))
.CommandType = xlCmdTable
.CommandText = Array("FILEB")
.Name = "PALM"
.FieldNames = True
.RowNumbers = False
.FillAdjacentFormulas = False
.PreserveFormatting = True
.RefreshOnFileOpen = False
.BackgroundQuery = True
.RefreshStyle = xlInsertDeleteCells
.SavePassword = False
.SaveData = True
.AdjustColumnWidth = True
.RefreshPeriod = 0
.PreserveColumnInfo = True
.SourceDataFile = "C:\Program Files\DumP\DATA\PALM.mdb"
.Refresh BackgroundQuery:=True
Sheets("FileC").Activate
Columns("A:E").Select
, _
, _
, _
.CommandText = Array("FILEC_DUE")
.Name = "PALM"
.FieldNames = True
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
Sheets("FileD").Activate
Columns("A:C").Select
, _
, _
, _
.CommandText = Array("FILED")
.Name = "PALM"
.FieldNames = True
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
Sheets("Perx").Activate
, _
, _
, _
.CommandText = Array("PER1GARA")
.Name = "PALM"
.FieldNames = True
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
Sheets("Pergaran").Activate
Columns("A:F").Select
, _
, _
, _
.CommandText = Array("PERGARAN")
.Name = "PALM"
.FieldNames = True
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
Sheets("Regasset").Activate
Columns("A:I").Select
, _
, _
, _
.CommandText = Array("REGASSET")
.Name = "PALM"
.FieldNames = True
.RowNumbers = False
.SaveData = True
.RefreshPeriod = 0
Tolone.Tolone
MsgBox "โหลดข้อมูลสมบูรณ์ì", vbOKOnly, "DumP"
Sheets("master").Activate
If Err > 0 Then
โดยใช้คำสั่งนี้ที่ปุ่มคำสั่ง Loadlone
- (146.01 KiB) Downloaded 72 times
อาจารครับหรือเพราะเราไปซ้อนโมดูลในคำสั่งที่เป็นโมดูล คำสั่งที่อยู่ใต้ Tolone.Tolone ทำงานครับ แต่คำสั่งที่อยู่ในTolone
ทำงานเฉพาะคำสั่ง
Sheet9.Activate
Sheet9.Range("T1").Value = "หนี้รวม"
