Export ข้อมูล ให้ชื่อไฟล์เป็นวันที่และเวลาปัจจุบันแบบอัตโนมัติได้ไหมครับ
Posted: Wed Jun 29, 2016 8:44 am
คลังคำตอบแห่งความรู้จากคนไทย เพื่อโลกที่ต้องการเข้าใจในสิ่งเล็ก ๆ อย่างลึกซึ้ง
https://www.snasui.com/
snasui wrote:คงต้องอาศัย VBA เข้ามาช่วยครับ
Dim FD As FileDialog
Dim Title As String
Dim vrtSelectedItem As Variant
Set FD = Application.FileDialog(msoFileDialogSaveAs)
With FD
.AllowMultiSelect = False
.Title = "Save File DataInput"
.InitialFileName = "DataInput " & Format(Now(), "ddmmyyyyhhnn") & ".xls"
If .Show = True Then
For Each vrtSelectedItem In .SelectedItems
DoCmd.OutputTo acOutputQuery, "qExportInput", acFormatXLS, vrtSelectedItem, True
Next vrtSelectedItem
MsgBox "No file was selected"
Dim Title As String
With FD
'Working in Excel 2000-2016
Dim fname As Variant
Dim NewWb As Workbook
Dim FileFormatValue As Long
'Check the Excel version
If Val(Application.Version) < 9 Then Exit Sub
If Val(Application.Version) < 12 Then
'Only choice in the "Save as type" dropdown is Excel files(xls)
'because the Excel version is 2000-2003
fname = Application.GetSaveAsFilename(InitialFileName:="", _
filefilter:="Excel Files (*.xls), *.xls", _
Title:="This example copies the ActiveSheet to a new workbook")
If fname <> False Then
'Copy the ActiveSheet to new workbook
ActiveSheet.Copy
Set NewWb = ActiveWorkbook
'We use the 2000-2003 format xlWorkbookNormal here to save as xls
NewWb.SaveAs fname, FileFormat:=-4143, CreateBackup:=False
NewWb.Close False
Set NewWb = Nothing
'Give the user the choice to save in 2000-2003 format or in one of the
'new formats. Use the "Save as type" dropdown to make a choice,Default =
'Excel Macro Enabled Workbook. You can add or remove formats to/from the list
fname = Application.GetSaveAsFilename(InitialFileName:="", filefilter:= _
" Excel Macro Free Workbook (*.xlsx), *.xlsx," & _
" Excel Macro Enabled Workbook (*.xlsm), *.xlsm," & _
" Excel 2000-2003 Workbook (*.xls), *.xls," & _
" Excel Binary Workbook (*.xlsb), *.xlsb", _
FilterIndex:=2, Title:="This example copies the ActiveSheet to a new workbook")
'Find the correct FileFormat that match the choice in the "Save as type" list
Select Case LCase(Right(fname, Len(fname) - InStrRev(fname, ".", , 1)))
Case "xls": FileFormatValue = 56
Case "xlsx": FileFormatValue = 51
Case "xlsm": FileFormatValue = 52
Case "xlsb": FileFormatValue = 50
Case Else: FileFormatValue = 0
End Select
'Now we can create/Save the file with the xlFileFormat parameter
'value that match the file extension
If FileFormatValue = 0 Then
MsgBox "Sorry, unknown file extension"
'Copies the ActiveSheet to new workbook
ActiveSheet.Copy
'Save the file in the format you choose in the "Save as type" dropdown
NewWb.SaveAs fname, FileFormat:= _
FileFormatValue, CreateBackup:=False
NewWb.Close False
Set NewWb = Nothing
End Ifไฟล์แนบครับsnasui wrote:แนบตัวอย่างไฟล์ ตัดมาเฉพาะที่เกี่ยวข้องกับกระทู้นี้พร้อม Code ที่ปรับมาเองแล้ว จะได้ช่วยดูได้ครับ
