index_match combo
Posted: Mon Sep 05, 2022 3:03 pm
by sna
Hi there!
"Level is given from B5:AF5 and Basic is given below the level accordingly so my query is e.g. level is 13 (given in G48 that I may change it) and basic is 53600 (given in H48 that I may change it) from the above table………. so If I write Previous Level e.g. 10 then in the column of level no 10 the number which is adjacent to less than 53600 should come. Similarly if I change the Previous Level number, it should change automatically"
Thanks
Re: index_match combo
Posted: Mon Sep 05, 2022 3:06 pm
by sna
Attached here
Posted: Mon Sep 05, 2022 4:25 pm
by sna
Attached
Posted: Mon Sep 05, 2022 7:36 pm
by norkaz
Hi guy,
I’m not sure that I know what you mean.
a) At level 13, what are the criteria for why it would be 53,600 at H48?
b) Then if it's changed from 13 to 10, what is the answer that it would be and why?
Could you please clarify that?
Norkaz
Posted: Mon Sep 05, 2022 9:57 pm
by sna
Hi
the criteria is upon level.
if I change level 10 or 9 or 3 or any level that I decide so, from that level, it should be closely lesser than 53600 e.g.
Because an employee has been pramoted to level 13 from 10 so If I need to check his previous basic from level 10........so it is
Posted: Mon Sep 05, 2022 10:48 pm
by norkaz
H49
=INDEX(B6:AF45,MATCH(H48,INDEX(B6:AF45,0,G48),0),G49)
I'm not sure I understand this correctly. I hope that's what you're looking for.
If it's not the right solution, could you please explain that again by giving me the answer as b) of my previous post?
Norkaz
Posted: Tue Sep 06, 2022 9:55 pm
by sna
I want Closer Value of the Data i.e. Less than Closer of the Value
note cell G48,H48,G49 are manual input.i mean to find closer value of H48.
Tks
Posted: Tue Sep 06, 2022 11:11 pm
by norkaz
Hi,
It's still not clear exactly for the less than closer of value.
If these cells are manual input --
G48 = 13
H48 = 53600
G49 = 10
what is the closer that you would like to be?
I mean what's the number that H49 would be from B6:AF45 ???
The number at H49 that need you to provide is the main point to find the right solution, please...
Norkaz
Posted: Sun Sep 11, 2022 8:52 pm
by sna
the closer value is 52600
Posted: Sun Sep 11, 2022 9:46 pm
by norkaz
In the column of level 10, the number 52600 appears in cell "K26".
How the number 52600 comes out, I mean what are the criteria that this number comes out?
Norkaz
Posted: Mon Sep 12, 2022 10:24 am
by sna
Thank you for your time,I got this question from a friend now he update me he found solution, please quit it.
Norkaz really appreciated what you help me so far
Posted: Mon Sep 12, 2022 1:27 pm
by norkaz
Always welcome.
Norkaz
