สวัสดีครับอาจารย์ผมมีปัญหามารบกวนอีกแล้วครับผม
คือProject งานผมพอรันแล้ว ระบบแจ้ง Run-time error 380 ครับ
ผมรบกวนอาจารย์ช่วยแนะนำแก้ไขปัญหาให้ผมหน่อยครับ..
ผมได้แนบไฟล์ด้วยครับ..
ขอบคุณอาจารย์มากครับผม...
txtSearch.SetFocus
txtSearch.Enabled = False
Private Sub OptionButton2_Change()
If OptionButton2.Value = True Then
txtName.Enabled = True
txtName.SetFocus
txtName.Enabled = False
With lstSearch
.ColumnCount = 12
.ColumnWidths = "0,50,50,50,80,35,30,30,50,50,60,80,50"
Private Sub txtSearch_keyDown(ByVal KeyCode As MSForms.ReturnInteger, ByVal Shift As Integer)
Select Case KeyCode
Case 13
If showList(txtSearch.Text) Then lstSearch.ListIndex = -1
End Select
Private Function showList(c As String) As Boolean
Dim rg As Range
c = Trim(c)
If c = "" Then showList = False: Exit Function
lstSearch.Clear
With Sheet1.Columns(3)
Set rg = .Find(c, LookIn:=xlValues, LookAt:=xlPart)
If rg Is Nothing Then showList = False: Exit Function
cAddr = rg.Address
i = 0
Do
If rg.Row > 1 Then
With lstSearch
.AddItem rg.Offset(0, -2).Address
.List(i, 1) = rg.Offset(0, -2).Value
.List(i, 2) = rg.Offset(0, -1).Value
.List(i, 3) = rg.Offset(0, 0).Value
.List(i, 4) = rg.Offset(0, 1).Value
.List(i, 5) = rg.Offset(0, 2).Value
.List(i, 6) = rg.Offset(0, 3).Value
.List(i, 7) = rg.Offset(0, 4).Value
.List(i, 8) = rg.Offset(0, 5).Value
.List(i, 9) = rg.Offset(0, 6).Value
.List(i, 10) = rg.Offset(0, 7).Value
i = i + 1
Set rg = .FindNext(rg)
Loop Until rg Is Nothing Or rg.Address = cAddr
showList = True
End Function
Rem:àÅ×Í¡ÃÒ¡ÒÃã¹ Listbox ãËéáÊ´§¢éÍÁÙÅ㹿ÍÃìÁ
Private Sub lstSearch_DblClick(ByVal Cancel As MSForms.ReturnBoolean)
wsFormEdit.showRecord Sheet1.Range(lstSearch.Value)
Unload Me
FormAdd_Data.Hide
wsFormEdit.Activate
Rem:¡´»ØèÁ Enter ã¹ Listbox ãËé»Ô´¿ÍÃìÁ¡ÅѺ价Õè¿ÍÃìÁ
Private Sub lstSearch_KeyPress(ByVal KeyAscii As MSForms.ReturnInteger)
If KeyAscii = 13 Then
If lstSearch.ListCount = 0 Then Exit Sub
Unload Me
wsFormEdit.Activate
Private Sub OptionButton1_Change()
If OptionButton1.Value = True Then
txtSearch.Enabled = True
txtSearch.SetFocus
txtName.SetFocus
With lstSearch
.ColumnCount = 12
Select Case KeyCode
Case 13
End Select
Dim rg As Range
c = Trim(c)
lstSearch.Clear
cAddr = rg.Address
i = 0
Do
If rg.Row > 1 Then
With lstSearch
i = i + 1
showList = True
End Function
