อยาก Save จาก userform1 ไปเก็บ sheet3 และมี password ป้องกันไว้
sooksun2009
Excel Ver: 2013,2016
Post by sooksun2009 »
รบกวนอาจารย์ช่วยปรับ code ให้หน่อยครับ คือ อยาก save จาก button save จาก form1 ไปเก็บไว้ sheet3 และต้องการ protect sheet ไว้ด้วยครับ ขอบคุณครับ
Private Sub CMB_Save_Click()
If Tb_FinishM1.Text = "" Then
MsgBox ("¡Ãسҡ´»ØèÁ Finsh ¡è͹ºÑ¹·Ö¡")
If MsgBox("¡ÃسҵÃǨÊͺ»ØèÁ Finish ¡è͹ºÑ¹·Ö¡?", vbOKCancel) = vbOK Then
' OK µÃǨÊͺ»ØèÁ Finish áÅéÇ
' Cancel ÂѧäÁèä´é¡´»ØèÁ Finish !!
Sheet3.Activate
Dim irow As Long
    Dim ws As Worksheet
    Set ws = Worksheets("Save")
    'find first empty row in database
    irow = ws.Cells(Rows.Count, 2) _
        .End(xlUp).Offset(1, 0).Row
    'Check for Id
    If Trim(Me.CB_CodeModel.Value) = "" Then
        Me.CB_CodeModel.SetFocus
        MsgBox "¡ÃسҡÃÍ¡ Model"
    'copy the data to the database
    ws.Cells(irow, 1).Value = Me.Tb_VinNo.Value
    ws.Cells(irow, 2).Value = Me.Lb_Model.Caption
    ws.Cells(irow, 3).Value = Me.Tb_Timein.Value
    ws.Cells(irow, 4).Value = Me.Tb_FinishM1.Value
    ws.Cells(irow, 5).Value = Me.Tb_FinishM2.Value
    ws.Cells(irow, 13).Value = Me.Tb_STDTM1.Value
    ws.Cells(irow, 14).Value = Me.Tb_STDTM2.Value
    ws.Cells(irow, 17).Value = Me.Tb_stopworkP1L.Value
    ws.Cells(irow, 18).Value = Me.Tb_stopworkP1L.Value
    ws.Cells(irow, 21).Value = Me.Tb_BreakM1.Value
    ws.Cells(irow, 22).Value = Me.Tb_BreakM2.Value
     ws.Cells(irow, 25).Value = Me.Tb_ContinM1.Value
    ws.Cells(irow, 26).Value = Me.Tb_ContinM2.Value
    ws.Cells(irow, 29).Value = Me.CB_Remark.Value
    ws.Cells(irow, 31).Value = Me.TB_SubModel.Value
    ws.Cells(irow, 32).Value = Me.TB_Trancefer.Value
    ws.Cells(irow, 33).Value = Me.TB_Katashiki.Value
    ws.Cells(irow, 34).Value = Me.TB_Sfx.Value
    ws.Cells(irow, 35).Value = Me.TB_ColorCode.Value
    'Clear the data
stopTimer1
stopTimer2
Sheet5.Range("A2").Value = ""
Sheet5.Range("R2").Value = ""
Sheet5.Range("V2").Value = ""
 Me.Tb_VinNo.Value = ""
Me.Lb_Model.Caption = ""
Me.Tb_Timein.Value = ""
Me.CB_CodeModel.Value = ""
Me.TB_SubModel.Value = ""
Me.TB_Trancefer.Value = ""
Me.TB_Sfx.Value = ""
Me.TB_Katashiki.Value = ""
Me.TB_ColorCode.Value = ""
Me.Tb_BreakM1.Value = ""
Me.Tb_ContinM1.Value = ""
Me.Tb_FinishM1.Value = ""
Me.Tb_CountDM1.Value = ""
Me.Tb_STDTM1.Value = ""
Me.Tb_RankM1.Value = ""
Me.Tb_AveM1.Value = ""
Me.Tb_PointM1.Value = ""
Me.Tb_BreakM2.Value = ""
Me.Tb_ContinM2.Value = ""
Me.Tb_FinishM2.Value = ""
Me.Tb_CountDM2.Value = ""
Me.Tb_STDTM2.Value = ""
Me.Tb_RankM2.Value = ""
Me.Tb_AveM2.Value = ""
Me.Tb_PointM2.Value = ""
Me.Tb_stopworkP1L.Value = ""
Me.Tb_stopworkP1R.Value = ""
Me.CB_Remark.Value = ""
RefreshColor
ActiveWorkbook.Save
Re: อยาก Save จาก userform1 ไปเก็บ sheet3 และมี password ป้องกันไว้
:D Code อยู่ใน Module ไหน ติดขัดตรงไหน อย่างไร กรุณาลำดับวิธีทดสอบพร้อมค่าที่ใช้ในการทดสอบ ผลลัพธ์ที่ต้องการหากว่าโปรแกรมทำงานถูกต้อง จะได้ช่วยเข้าถึงปัญหาโดยไวครับ
sooksun2009
Code ใน userform1 ทีปุ่ม save คือต้องการ save ไปไว้ Sheet3(save) ทีนี่ sheet3 ผมตั้ง password ไว้ ป้อง user ไปแก้ไข.
ปัญหาคือเวลาเรากด save มันขึ้น debug ไม่ให้ save ขอบคุณครับ
:D ก่อนจะบันทึกให้ Unprotect เสียก่อน เมื่อบันทึกแล้วค่อย Protect ไว้เช่นเดิม ดูตัวอย่างการใช้งานที่นี่ครับ viewtopic.php?t=1743#p11117
sooksun2009
เข้าไปอ่านแล้วยังติด Bugเหมือนเดิมครับ ขอบคุณครับ
:D แนบไฟล์ที่ปรับปรุง Code ตามที่ผมแนะนำแล้วยังติด Bug มาดูกันจะได้ช่วยตรวจสอบได้
หากทำถูกต้องจะต้องไม่ติด Bug ยกเว้นว่า Code มีติด Bug อยู่ก่อนหน้านั้นแล้วหรือคีย์ Password ในตอน Unprotect ไว้ไม่ถูกต้องครับ
sooksun2009
snasui wrote: Thu Jul 19, 2018 10:17 pm :D แนบไฟล์ที่ปรับปรุง Code ตามที่ผมแนะนำแล้วยังติด Bug มาดูกันจะได้ช่วยตรวจสอบได้
ขอบคุณอาจารย์มากครับ ปัญหาคือ save ครั้งไม่เป็น พอบันทึกใหม่แล้ว save ครั้งที่2จะเป็นเหมือนเดิมครับ
:D แนบไฟล์ที่ยังเป็นปัญหามาด้วยจะได้ช่วยตรวจสอบให้ได้ครับ
sooksun2009
snasui wrote: Fri Jul 20, 2018 10:09 pm :D แนบไฟล์ที่ยังเป็นปัญหามาด้วยจะได้ช่วยตรวจสอบให้ได้ครับ
:D ผมทดสอบแล้วไม่พบการ Debug จากการป้องกันและปลดการป้องกันครับ
sooksun2009
snasui wrote: Sat Jul 21, 2018 7:45 am :D ผมทดสอบแล้วไม่พบการ Debug จากการป้องกันและปลดการป้องกันครับ
อาจารย์ลองสองครั้งหรือยังครับ มันจะเป็นครั้งที่สอง
:D ลองปรับการปลด Password โดยย้ายบรรทัดมาเป็นด้านล่างคือก่อนที่จะบันทึกข้อมูลครับ
ActiveSheet.Unprotect Password:="sooksun040057"
ที่ผ่านมาผมน่าจะ Debug ข้ามบรรทัดที่เป็น Validate เช่นเช็ค Object ว่างจึงอาจจะไม่พบครับ
sooksun2009
snasui wrote: Sat Jul 21, 2018 2:16 pm :D ลองปรับการปลด Password โดยย้ายบรรทัดมาเป็นด้านล่างคือก่อนที่จะบันทึกข้อมูลครับ
ได้แล้วครับขอบคุณครับ
