ต้องการค้นหาข้อมูลด้วย Combobox และให้ข้อมูลมาเเสดงใน Listbox
Posted: Mon Sep 14, 2020 11:35 am
by thinatda
ต้องการค้นหาข้อมูลด้วย Combobox โดยเลือกจาก รายการสารมาตรฐาน และ Lot no.ให้ข้อมูลมาเเสดงใน Listbox ค่ะ
ตอนนี้กด F5 ติด error Subscript out of range
Dim dict, key
Dim lastrow As Long
lastrow = Application.WorksheetFunction.CountA(Range("B:B"))
With Sheets("Sheet2").Range("B2:B" & lastrow)
dict = .Value
With CreateObject("scripting.dictionary")
comparemode = 1 'vbTextCompare – case of words doesn't matter: apple is the same as Apple
For Each key In dict
    If Not .exists(key) Then .Add key, Nothing
Next
If .Count Then Me.cbRegion.List = Application.Transpose(.keys)
With Sheets(Sheet2).Range("H2:H" & lastrow)
dict = .Value
.comparemode = 1
Next
If .Count Then Me.cbItem.List = Application.Transpose(.keys)
Private Sub FilterData()
Dim Region As String
Dim Item_Type As String
Dim myDB As Range
With Me
If .cbRegion.ListIndex < 0 Or .cbItem.ListIndex < 0 Then Exit Sub
Region = .cbRegion.Value
Item_Type = .cbItem.Value
With ActiveWorkbook.Sheets("Sheet2")
Set myDB = .Range("B1:T1").Resize(.Cells(.Rows.Count, 1).End(xlUp).Row)
With myDB
.AutoFilter 'remove filters
.AutoFilter Field:=1, Criteria1:=Region ' filter data
.SpecialCells(xlCellTypeVisible).AutoFilter Field:=3, Criteria1:=Item_Type 'filter data again
Call UpdateListBox(Me.MyListbox, myDB, 1)
.AutoFilter
Sub UpdateListBox(MyListbox As MSForms.ListBox, myDB As Range, columnToList As Long)
Dim cell As Range, dataValues As Range
If myDB.SpecialCells(xlCellTypeVisible).Count > myDB.Columns.Count Then
    Set dataValues = myDB.Resize(myDB.Rows.Count + 1)
   MyListbox.Clear ' we clear the listbox before adding new elements
    For Each cell In dataValues.Columns(columnToList).SpecialCells(xlCellTypeVisible)
        With Me.MyListbox
        .AddItem cell.Value
        .List(.ListCount - 1, 1) = cell.Offset(0, 1).Value
        .List(.ListCount - 1, 2) = cell.Offset(0, 2).Value
        .List(.ListCount - 1, 3) = cell.Offset(0, 3).Value
         .List(.ListCount - 1, 4) = cell.Offset(0, 4).Value
        .List(.ListCount - 1, 5) = cell.Offset(0, 5).Value
        .List(.ListCount - 1, 6) = cell.Offset(0, 6).Value
         .List(.ListCount - 1, 7) = cell.Offset(0, 7).Value
        .List(.ListCount - 1, 8) = cell.Offset(0, 8).Value
        .List(.ListCount - 1, 9) = cell.Offset(0, 9).Value
         .List(.ListCount - 1, 10) = cell.Offset(0, 10).Value
        .List(.ListCount - 1, 11) = cell.Offset(0, 11).Value
        .List(.ListCount - 1, 12) = cell.Offset(0, 12).Value
         .List(.ListCount - 1, 13) = cell.Offset(0, 13).Value
        .List(.ListCount - 1, 14) = cell.Offset(0, 14).Value
        .List(.ListCount - 1, 15) = cell.Offset(0, 15).Value
         .List(.ListCount - 1, 16) = cell.Offset(0, 16).Value
        .List(.ListCount - 1, 17) = cell.Offset(0, 17).Value
    Next cell
    MyListbox.Clear ' if no match then clear listbox
MyListbox.SetFocus
Re: ต้องการค้นหาข้อมูลด้วย Combobox และให้ข้อมูลมาเเสดงใน Listbox
Posted: Mon Sep 14, 2020 12:09 pm
by logic
กด f8 ไปทีละขั้น ๆ ดูก่อนว่าติดบรรทัดไหนครับ
Posted: Mon Sep 14, 2020 1:10 pm
by thinatda
logic wrote: Mon Sep 14, 2020 12:09 pm กด f8 ไปทีละขั้น ๆ ดูก่อนว่าติดบรรทัดไหนครับ
บรรทัดนี้ค่ะ
Posted: Mon Sep 14, 2020 1:32 pm
by logic
ไฟล์นั้นไม่มีชีตที่ชื่อ Sheet2 ก็เลยเออเรอร์ครับ
Posted: Mon Sep 14, 2020 1:36 pm
by thinatda
logic wrote: Mon Sep 14, 2020 1:32 pm ไฟล์นั้นไม่มีชีตที่ชื่อ Sheet2 ก็เลยเออเรอร์ครับ
ตอนนี้ไม่ error แล้วค่ะ แต่ข้อมูลไม่แสดงใน Listbox ค่ะ
Posted: Mon Sep 14, 2020 7:50 pm
by logic
ก็กด f8 เหมือนเดิมแหละครับ แล้วค่อยบอกมาว่าพอถึงบรรทัดไหนที่มันต้องได้ข้อมูลแล้วมันยังไม่ได้
Posted: Tue Sep 15, 2020 8:32 am
by thinatda
logic wrote: Mon Sep 14, 2020 7:50 pm ก็กด f8 เหมือนเดิมแหละครับ แล้วค่อยบอกมาว่าพอถึงบรรทัดไหนที่มันต้องได้ข้อมูลแล้วมันยังไม่ได้
ติดบรรทัดนี้ค่ะ .List(.ListCount - 1, 10) = cell.Offset(0, 10).Value
        With Me.MyListbox
        .AddItem cell.Value
    Next cell
MyListbox.SetFocus
Posted: Tue Sep 15, 2020 10:32 am
by thinatda
ตอนนี้แก้ได้แล้วนะค่ะ ขอบคุณค่ะ
