Make journal entry
sna
Excel Ver: Excel 365
Make journal entry
Post by sna »
Hi Dear!
I have a template for listing accrued expenses .
I want to make a journal entry from Menu Sheet and Transfer to Journal Sheet .I need only formula.the expected Result in Journal Sheet also provided.
BTW how to arrange data in Menu Sheet to be easier to transfer to sheet Journal.
Best wishes,
Re: Make journal entry
:D Try with these formulas:
Sheet Menu
  1. K8
    =IF(G8="","",COUNTIF(OFFSET(H8,0,0,IFERROR(MATCH(TRUE,INDEX(G9:$G$300<>"",0),0),1)),"<>")+1)
    Enter > Copy down
  2. L8
    =IF(K8="","",SUM(K$8:K8)-K8+1)
    Enter > Copy down
Sheet Journal
  1. A11
    =IF(ROWS(A$11:A11)=LOOKUP(ROWS(A$11:A11),Menu!$L$8:$L$32),LOOKUP(ROWS(A$11:A11),Menu!$L$8:$L$32,Menu!$G$8:$G$32),"")
    Enter > Copy down
  2. B11
    =IF(A11<>"","",""&INDEX(Menu!$H$8:$H$300,MATCH(ROWS(B$11:B11),Menu!$L$8:$L$32)+ROWS(B$11:B11)-MATCH(2,INDEX(1/($A$11:A11<>""),0))-1))
    Enter > Copy down
sna
Post by sna »
Thank you one more thing how we can get amount from total price?
:D Please attach the latest file with formula above and explain the result what you want.
sna
Post by sna »
Hi Dear,
I put some examples of amount in journal .it should come from menu in column I and place in journal column D.
Thanks
:D Your data on sheet Menu should look like this picture.
Sheet Journal cell D11 can input this formula.
=IF(ROWS(A$11:A11)=LOOKUP(ROWS(A$11:A11),Menu!$M$8:$M$32),LOOKUP(ROWS(A$11:A11),Menu!$M$8:$M$32,Menu!$H$8:$H$32),-INDEX(Menu!$J$8:$J$300,MATCH(ROWS(B$11:B11),Menu!$M$8:$M$32)+ROWS(B$11:B11)-MATCH(2,INDEX(1/($A$11:A11<>""),0))-1))
Enter and copy down.
sna
Post by sna »
Thank you so much 🙏
