remove dates and shapes
sna
Excel Ver: Excel 365
Post by sna »
Hi Dear,
I have written a code to delete signatures for all sheets and it works fine but I want to ask for your help how to delete cell contents with dates in all sheets.
Sub DeletePics()
Dim sht As Worksheet
Application.ScreenUpdating=False
    For Each sht In ThisWorkbook.Worksheets
    sht.Activate
    ActiveSheet.DrawingObjects.Delete
    Next sht
Best Wishes,
Re: remove dates and shapes
Sample code
Sub DeletePics()
Dim c As Range
    sht.Activate
    For Each c In Range("a1:z100")
    With c
        If .Value = "Date:" Then .Offset(, 1).Resize(, 2).ClearContents
    Next c
    Next sht
sna
Post by sna »
Thank you 😊
