issue sum
sna
Excel Ver: Excel 365
issue sum
Post by sna »
Hi Dear,
I need your help how to sum until reach a certain value of a cell.
I have attached a template.
The result in color cells
Thanks
sna
Re: issue sum
Post by sna »
Here's an attached
Bo_ry
Excel Ver: MS 365
Re: issue sum
Post by Bo_ry »
C2
=IF(SUM(B$1:B1)<$A$2,MIN($A$2,SUM(B$2:B2)),"")
sna
Re: issue sum
Post by sna »
Thank you 😊
