multiple times base on value
Posted: Tue Dec 14, 2021 10:51 am
by sna
Hi Dear,
Good morning, hope you are all doing well.
I need your help how to return multiple times of value base on Next cell .
I can create a helper column and come up with results.
Is there any one way formula to do that without helper?
Thanks
Re: multiple times base on value
Posted: Tue Dec 14, 2021 11:36 am
by norkaz
G2
=INDEX(B:B,AGGREGATE(15,6,ROW($C$2:$C$4)/(COLUMN($A$2:$Z$2)<=$C$2:$C$4),ROWS($C$2:C2)))&CHAR(ROWS($G$2:G3)-VLOOKUP(ROWS($G$2:G2),A$2:A$4,1)+64)
Norkaz
Posted: Tue Dec 14, 2021 3:00 pm
by norkaz
If no need or without column "A"
G2
=IFERROR(INDEX(B:B,AGGREGATE(15,6,ROW($C$2:$C$4)/(COLUMN($A$2:$Z$2)<=$C$2:$C$4),ROWS($C$2:C2)))&CHAR(ROWS($C$2:C3)-AGGREGATE(15,6,MATCH(ROW($C$2:$C$4),AGGREGATE(15,6,ROW($C$2:$C$4)/(COLUMN($A$2:$Z$2)<=$C$2:$C$4),ROW($C$2:$C$99)-ROW($C$2)+1),0)/((COLUMN($A$2:$Z$2)<=$C$2:$C$4)),ROWS($C$2:C2))+64),"")
Ctrl + Shift + Enter
Norkaz
Posted: Fri Dec 24, 2021 6:50 pm
by sna
Thank you
