Start & End num
sna
Excel Ver: Excel 365
Start & End num
Post by sna »
Hi Dear,
I need your help how to write a formula to cope with start and end number in excel.
I attach a file
Thank in advance
norkaz
Excel Ver: 2013,365
Re: Start & End num
Post by norkaz »
Hi Guy
Which column(s) that you need to place the formula (C D E)?
Norkaz
norkaz
Excel Ver: 2013,365
Re: Start & End num
Post by norkaz »
Quite not sure what you need to place the formula(s).
However, try this.
D2
=IFERROR(INDEX(A:A,AGGREGATE(15,6,ROW($A$2:$A$22)/($A$2:$A$22+1<>$A$3:$A$23),ROWS($D$2:D2))),LOOKUP(9^9,$A$2:$A$23))
C2
=INDEX(A:A,IFERROR(MATCH(D1,$A$2:$A$23,0),0)+ROW($A$2))
E2
=D2-C2
If it does not match your requirement, please provide more explanation.
Norkaz
sna
Re: Start & End num
Post by sna »
thank you 🙂
