Sub Macro1()
' Macro1 Macro
Dim myRange As Range
Dim ce As Range
Open "d:\sample.txt" For Output As #1
Set myRange = Worksheets("INPUT").Range("A1:A1")
answer = Application.WorksheetFunction.Min(myRange)
Range("A1").Select
Sheets("OUTPUT").Select
For Each ce In Range("A1" & ":A" & answer)
Print #1, ce.Value
Next ce
Close #1
Sheets("INPUT").Select
Range("A1").Select
MsgBox ("Done")
Sub test()
Dim objStream
Set objStream = CreateObject("ADODB.Stream")
Dim ce As Range
objStream.Charset = "UTF-8"
objStream.Open
objStream.SaveToFile "C:\Users\AccountName\Desktop\sample.txt", 2
Open "C:\Users\AccountName\Desktop\sample.txt" For Output As #1
Set myRange = Worksheets("INPUT").Range("A1:A10")
For Each ce In myRange
Print #1, ce.Value
Next ce
Close #1
MsgBox ("Done")
Sub test()
Dim objStream
Dim ce As Range
objStream.Open
Print #1, ce.Value
Next ce
Close #1
MsgBox ("Done")
