ขึ้น compile error : Type mismatch เเก้ไขอย่างไรครับ
chaloemsak
Post by chaloemsak »
Option Explicit
Dim NumCate As Integer
Dim NumN() As Integer
Dim NumCapa() As Integer
Dim NumFixedCost() As Integer
Dim NumVarCost() As Double
Dim NumLCost() As Double
Dim NumSpeed() As Double
Dim NumCust() As Integer
Dim NumX() As Integer
Dim NumY() As Integer
Dim NumNeed() As Integer
Dim NumTimeStart() As Integer
Dim NumTimeFinis() As Integer
Dim NumTimeTra() As Integer
Dim NumFine() As Integer
Dim j As Integer
Public Sub RdINP(Fn As String).............................................ขึ้น debug บรรทัดนี้ครับ
Dim FolderName As String
FolderName = "C:\VRP\" & Fn
Dim wbk As Workbook
Set wbk = Workbooks.Open(FolderName)
NumCate = wbk.Worksheets("Sheet1").Range("B1")
ReDim NumN(1 To NumCate)
ReDim NumCapa(1 To NumCate)
ReDim NumFixedCost(1 To NumCate)
ReDim NumVarCost(1 To NumCate)
ReDim NumLCost(1 To NumCate)
ReDim NumSpeed(1 To NumCate)
For i = 1 To NumCate
NumN(i) = wbk.Worksheets("Sheet1").Range("B6").Offset(i, 0)
NumCapa(i) = wbk.Worksheets("Sheet1").Range("C6").Offset(i, 0)
NumFixedCost(i) = wbk.Worksheets("Sheet1").Range("D6").Offset(i, 0)
NumVarCost(i) = wbk.Worksheets("Sheet1").Range("E6").Offset(i, 0)
NumLCost(i) = wbk.Worksheets("Sheet1").Range("F6").Offset(i, 0)
NumSpeed(i) = wbk.Worksheets("Sheet1").Range("G6").Offset(i, 0)
NumCust = wbk.Worksheets("Sheet1").Range("B2")
ReDim NumX(1 To NumCust)
ReDim NumY(1 To NumCust)
ReDim NumNeed(1 To NumCust)
ReDim NumTimeStart(1 To NumCust)
ReDim NumTimeFinis(1 To NumCust)
ReDim NumTimeTra(1 To NumCust)
ReDim NumFine(1 To NumCust)
For i = 1 To NumCust
NumX(i) = wbk.Worksheets("Sheet1").Range("J6").Offset(i, 0)
NumY(i) = wbk.Worksheets("Sheet1").Range("K6").Offset(i, 0)
NumNeed(i) = wbk.Worksheets("Sheet1").Range("L6").Offset(i, 0)
NumTimeStart(i) = wbk.Worksheets("Sheet1").Range("M6").Offset(i, 0)
NumTimeFinis(i) = wbk.Worksheets("Sheet1").Range("N6").Offset(i, 0)
NumTimeTra(i) = wbk.Worksheets("Sheet1").Range("O6").Offset(i, 0)
NumFine(i) = wbk.Worksheets("Sheet1").Range("P6").Offset(i, 0)
MsgBox "Done"
Re: ขึ้น compile error : Type mismatch เเก้ไขอย่างไรครับ
:D กรุณาแนบไฟล์ที่มี Code นี้มาด้วย จะได้สะดวกในการตรวจสอบ
Code ในบรรทัดที่ Error นั้นไม่ได้อยู่เดี่ยว ๆ เนื่องจากมีการรับตัวแปรเข้ามาทำงานต่อ จะต้องมี Code อื่นมาเรียกใช้อีกที
สำหรับการโพสต์ Code จะต้องโพสต์ให้แสดงเป็น Code แทนการแสดงความความปกติ เพื่อสะดวกในการอ่านและให้แยกกันได้สะดวกกับข้อความปกติ ดูตัวอย่างได้จากกฎการใช้บอร์ดข้อ 5 ด้านบนครับ :roll:
chaloemsak
ช่วยตรวจสอบให้ผมหน่อยครับ
Option Explicit
Private Sub ReadInput_Click()
Call RdINP("problem 1.xlsx")
Option Explicit
Dim j As Integer
Dim wbk As Workbook
MsgBox "Done"
:D แนบไฟล์ที่เกี่ยวข้องมาด้วยครับ
snasui wrote: Sun Jan 13, 2019 6:52 am กรุณาแนบไฟล์ที่มี Code นี้มาด้วย จะได้สะดวกในการตรวจสอบ
chaloemsak
นี่ครับมี 2 ไฟล์
:D เปลี่ยนการประกาศตัวแปรจาก Dim NumCust() As Integer เป็น Dim NumCust As Integer ครับ
chaloemsak
ได้เเล้วครับ ขอบคุณมากๆนะครับที่ช่วยตรวจให้ผม
