รบกวนตรวจสอบ script macro ที่ใช้ในการ pivot data ค่ะ
Posted: Mon Jun 01, 2020 11:59 am
ต้องการเขียนคำสั่ง Macro ให้สามารถ pivot ได้โดยข้อมูลดิบที่นำมา pivot จะเพิ่มขึ้นทุกเดือน แต่ติดปัญหา error ที่บันทัด 12- 15 ค่ะ
Sheets.Add After:=ActiveSheet
Sheets("Sheet4").Select
Sheets("Sheet4").Name = "By System"
'pivot Macro
Range("A1").Select
Dim Data As Range
With ActiveSheet
Set Data = .UsedRange
Sheets.Add
ActiveWorkbook.PivotCaches.Create(SourceType:=xlDatabase, SourceData:= _
Data, Version:=xlPivotTableVersion15).CreatePivotTable _
TableDestination:="Sheet1!R3C1", TableName:="PivotTable1", DefaultVersion _
Sheets("Sheet1").Select
Cells(3, 1).Select
ActiveWorkbook.ShowPivotTableFieldList = True
ActiveSheet.PivotTables("PivotTable5").AddDataField ActiveSheet.PivotTables( _
"PivotTable5").PivotFields("Customer and Information Detail" & Chr(10) & "Incident No"), _
"Count of Customer and Information Detail" & Chr(10) & "Incident No", xlCount
With ActiveSheet.PivotTables("PivotTable5").PivotFields("No.")
.Orientation = xlColumnField
.Position = 1
With ActiveSheet.PivotTables("PivotTable5").PivotFields( _
"Work around" & Chr(10) & "Sub Category")
.Orientation = xlRowField
.Position = 1
Range("A4").Select
.InGridDropZones = True
.RowAxisLayout xlTabularRow
ActiveSheet.PivotTables("PivotTable5").PivotSelect _
"'Work around" & Chr(10) & "Sub Category'[All]", xlLabelOnly, True
Range("N5").Select
ActiveSheet.PivotTables("PivotTable5").PivotFields("Work around" & Chr(10) & "Sub Category"). _
AutoSort xlDescending, "Count of Customer and Information Detail" & Chr(10) & "Incident No", _
ActiveSheet.PivotTables("PivotTable5").PivotColumnAxis.PivotLines(13), 1
Range("A3:N24").Select
Range("A13").Activate
