sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Fri Nov 26, 2021 1:02 pm
Hi Dear
I need your help how to highlight cells for consecutive zero Without using helper column
I attach a sample for your reference
(With helper column)
Thank
Supachok
Posts: 1014 Joined: Wed Jun 18, 2014 11:11 am
Excel Ver: 2013
by Supachok » Fri Nov 26, 2021 2:50 pm
can we use
"conditional formatting"
Set criteria = 0
then define your display color
sna
by sna » Sat Nov 27, 2021 9:21 am
no I try this by my own before I post here
sna
by sna » Sat Nov 27, 2021 9:26 am
the solution you suggest would color all zeros,i mean consecutive zero by rows
Posts: 31271 Joined: Sun Jan 24, 2010 12:33 pm
by snasui » Sat Nov 27, 2021 10:23 am
Please try this conditional formatting procedure,
Select A2:J8
Use this formula in 'Format values where this formula is true' as picture below
=IF(COLUMNS($A2:A2)=1,A2=0,OR(A2&OFFSET(A2,0,-1)="00",A2&B2="00"))
sna
by sna » Sat Nov 27, 2021 12:49 pm
as great as always.thank you
