อาจารย์ครับตอนแรกใช้งานได้แล้วแต่พอเริ่มทำเรื่อยๆเพิ่มโค๊ดอื่นเรื่อย ทำไมเวลา scan 10021 ข้อมูลไม่ลบครับ
โค๊ดที่ error ครับ
Worksheets("IN").Cells(emptyrow - 1, 1).EntireRow.Delete
Private Sub TextBox2_AfterUpdate()
With Workbooks("DataX.xlsx").Worksheets("Sheet1")
Set rngVlp = .Range("E2", .Range("F" & .Rows.Count))
If Me.TextBox2.Text = "" Then Exit Sub
If WorksheetFunction.CountIf(Workbooks("DataX.xlsx").Worksheets("Sheet1").Range("E:F"), Me.TextBox2.Value) = 0 Then
Call Sample2
'Me.TextBox2.Value = ""
MsgBox "Not found."
Me.TextBox10 = Application.VLookup(CLng(Me.TextBox2.Text), rngVlp, 2, 0)
Private Sub TextBox5_AfterUpdate()
Set rngVlp = .Range("a2", .Range("d" & .Rows.Count).End(xlUp))
With ThisWorkbook.Worksheets("IN")
emptyrow = .Range("a" & .Rows.Count).End(xlUp).Offset(1, 0).Row
If Me.TextBox5.Text = "10021" Then
Me.TextBox11.Text = Application.WorksheetFunction.Sum(Range("H3:H1048576"))
If Me.TextBox5.Text = "" Then Exit Sub
If WorksheetFunction.CountIfs(Workbooks("DataX.xlsx").Worksheets("Sheet1").Range("A:A"), Me.TextBox5.Value, _
Workbooks("DataX.xlsx").Worksheets("Sheet1").Range("E:E"), Me.TextBox2.Value) = 0 Then
Call Sample2
'Me.TextBox5.Value = ""
MsgBox "Please Check Information"
Me.TextBox6.Text = Application.VLookup(CLng(Me.TextBox5.Text), rngVlp, 2, 0)
Me.TextBox7.Text = Application.VLookup(CLng(Me.TextBox5.Text), rngVlp, 3, 0)
Me.TextBox8.Text = Application.VLookup(CLng(Me.TextBox5.Text), rngVlp, 4, 0)
With Worksheets("IN")
.Cells(emptyrow, 1).Value = TextBox1.Value
.Cells(emptyrow, 2).Value = TextBox2.Value
.Cells(emptyrow, 3).Value = ComboBox1.Value
.Cells(emptyrow, 4).Value = TextBox5.Value
.Cells(emptyrow, 5).Value = TextBox6.Value
.Cells(emptyrow, 6).Value = TextBox7.Value
.Cells(emptyrow, 7).Value = TextBox8.Value
.Cells(emptyrow, 8).Value = TextBox9.Value
Dim total As Long
total = WorksheetFunction.Sum(Range("H3:H1048576"))
Range("A1").Value = total
Range("C1") = TextBox10.Value
If Range("A1").Value > Range("C1") Then
Call Sample2
MsgBox "TOTAL NUMBER ERROR"
Dim lsRow As Long
With Sheets("IN")
lsRow = .Range("a" & .Rows.Count).End(xlUp).Row
ListBox1.RowSource = Sheets("IN").Range("A3:H" & lsRow).Address(external:=True)
With ListBox1
.ListIndex = .ListCount - 1
.Selected(.ListCount - 1) = True
