#If VBA7 Then
Public Declare PtrSafe Function SetTimer Lib "user32" ( _
ByVal HWnd As Long, ByVal nIDEvent As LongLong, _
ByVal uElapse As Long, ByVal lpTimerFunc As LongLong) As Long
Public Declare PtrSafe Function KillTimer Lib "user32" ( _
ByVal HWnd As Long, ByVal nIDEvent As Long) As Long
#Else
Public Declare Function SetTimer Lib "user32" ( _
ByVal HWnd As Long, ByVal nIDEvent As Long, _
ByVal uElapse As Long, ByVal lpTimerFunc As Long) As Long
Public Declare Function KillTimer Lib "user32" ( _
#End If
Public TimerID As Long, TimerSeconds As Single, tim As Boolean
Dim Counter As Long
'~~> Start Timer
Sub StartTimer()
'~~ Set the timer for 1 second
TimerSeconds = 1
TimerID = SetTimer(0&, 0&, TimerSeconds * 1000&, AddressOf TimerProc)
'~~> End Timer
Sub EndTimer()
KillTimer 0&, TimerID
Sub TimerProc(ByVal HWnd As Long, ByVal uMsg As Long, _
ByVal nIDEvent As Long, ByVal dwTimer As Long)
'~~> Update value in Sheet 1
Sheet1.Range("A1").Value = Time ' <~~ โชว์ในเซลล์
UserForm1.Label1.Caption = Time ' <~~ โชว์ใน label
UserForm1.TextBox1.Text = Time ' <~~ โชว์ใน textbox
#If VBA7 Then
#Else
#End If
Dim Counter As Long
'~~> Start Timer
Sub StartTimer()
TimerSeconds = 1
'~~> End Timer
Sub EndTimer()
#If VBA7 Then
#Else
#End If
Dim TimerActive As Boolean
Sub StartTimer()
Start_Timer
Public Sub Start_Timer()
TimerActive = True
Application.OnTime Now() + TimeValue("00:00:01"), "Timer"
Public Sub Stop_Timer()
TimerActive = False
Private Sub Timer()
If TimerActive Then
' ActiveSheet.Cells(1, 1).Value = Time
รายรับ1.Label18.Caption = Time
Sub StartTimer()
Start_Timer
TimerActive = True
TimerActive = False
Private Sub Timer()
If TimerActive Then
