sumup
sna
Excel Ver: Excel 365
sumup
Post by sna »
Hi Dear,
I need your help for a query.
I want to sum values between Order Numbers and input in cell C align with order number and return last value aligned with order number and input in cell D.
I don't want to fill blank with above cell and do the calculation.
The expected result also provided in column C and D.
Is it possible to do so?
Best wishes
Re: sumup
:D Please update your excel version, see the link below.
http://snasui.com/viewtopic.php?f=6&p=103177#p103177
sna
Re: sumup
Post by sna »
I use Excel 2013
Re: sumup
:D Try with these formulas.
  1. C2
    =IF(A2<>"",SUM(OFFSET(B2,0,0,SMALL(FREQUENCY(IF($A$2:$A$14="",ROW($A$2:$A$14)),IF($A$2:$A$14<>"",ROW($A$2:$A$14))),COUNTIF(A$2:A2,"<>")+1)+1)),"")
    Enter > Copy down
  2. D2
    =IF(A2<>"",OFFSET(B2,SMALL(FREQUENCY(IF($A$2:$A$14="",ROW($A$2:$A$14)),IF($A$2:$A$14<>"",ROW($A$2:$A$14))),COUNTIF(A$2:A2,"<>")+1),0),"")
    Enter > Copy down
