issue of rank
sna
Excel Ver: Excel 365
issue of rank
Post by sna »
Hi Dear
I need your help for ranking the duplicate
Also attached with expected output.
Thank
sna
Re: issue of rank
Post by sna »
Cancelled
Re: issue of rank
:D The example formula in F2 is:
=MATCH(C2,AGGREGATE(14,6,$C$2:$C$11/(MATCH($C$2:$C$11,$C$2:$C$11,0)=ROW($C$2:$C$11)-ROW($C$2)+1),INDEX(ROW($C$2:$C$11)-ROW($C$2)+1,0)),0)
Enter > Copy down
sna
Re: issue of rank
Post by sna »
It is not like I need
Re: issue of rank
:D The unique list of your data is:
100
95
94
90
80
Why the result of 80 is 4 instead 5?
sna
Re: issue of rank
Post by sna »
It should 4 base on group because I don't care duplicate
Re: issue of rank
:D Please explain more detail, where is group?
I think each item in unique list is represent to a group and 80 is group 5 not 4.
sna
Re: issue of rank
Post by sna »
it misses a number
Example - Section A should read 1,1,2,3,4
and Section B should read 1,2,2,3,4 because I don't need to skip number.is it possible?
Thanks
Re: issue of rank
:D Can you compare your result with condition by attach file?
Point to your data and explain what condition you use for the result of that data.
My post at #3 not skip any number.
sna
Re: issue of rank
Post by sna »
Hi dear
In Group A we have unique list:
100
95
94
80
Re: issue of rank
:D What is Group A in your attach file?
sna
Re: issue of rank
Post by sna »
Hi dear in column B we have group A and B .
A:5 and B:5
Re: issue of rank
:D OK, I see. Please try with this formula:
F2
=MATCH(C2,AGGREGATE(14,6,$C$2:$C$11/($B$2:$B$11=B2)/(MATCH($B$2:$B$11&$C$2:$C$11,$B$2:$B$12&$C$2:$C$11,0)=ROW($C$2:$C$11)-ROW($C$2)+1),INDEX(ROW($C$2:$C$11)-ROW($C$2)+1,0)),0)
sna
Re: issue of rank
Post by sna »
Thank you 🙏
