เปลี่ยน VBA AUTO Email lotus ไป outlook
Posted: Fri Nov 08, 2019 11:25 am
ถ้าต้องการเปลี่ยนย้ายโปรแกรมจะต้องแก้ ตรงไหนบ้างครับ
Sub Notes_Email_Excel_Cells()
Dim NSession As Object
Dim NDatabase As Object
Dim NUIWorkSpace As Object
Dim NDoc As Object
Dim NUIdoc As Object
Dim Attachment1 As String
Dim Attachment2 As String
Dim AttachME As Object
Dim EmbedObj1 As Object
Set NSession = CreateObject("Notes.NotesSession")
Set NUIWorkSpace = CreateObject("Notes.NotesUIWorkspace")
Set NDatabase = NSession.GetDatabase("", "")
If Not NDatabase.IsOpen Then
NDatabase.OPENMAIL
'Create a new document
Set NDoc = NDatabase.CreateDocument
With NDoc
.SendTo = Range("P6:P11").Value 'CHANGE THIS
.CopyTo = Range("P12:P20").Value
.Subject = Range("P4").Value
NDoc.SAVEMESSAGEONSEND = True
Attachment1 = Range("P5")
Attachment2 = Range("Q5")
If Attachment1 <> "" Then
Set AttachME = NDoc.CREATERICHTEXTITEM("attachment1")
Set EmbedObj1 = AttachME.EMBEDOBJECT(1454, "attachment1", Range("P5"), "") 'Required File Name
If Attachment2 <> "" Then
Set AttachME = NDoc.CREATERICHTEXTITEM("attachment2")
Set EmbedObj1 = AttachME.EMBEDOBJECT(1454, "attachment2", Range("Q5"), "") 'Required File Name
'Email body text, including marker text which will be replaced by the Excel cells
.body = Range("B4").Value & vbCr & vbCr & Range("B4:E15").Value
.Save True, False
'Edit the just-created document to copy and paste the Excel cells into it
Set NUIdoc = NUIWorkSpace.EDITDocument(True, NDoc)
With NUIdoc
'Find the marker text in the Body item
.GotoField ("Body")
' .FINDSTRING "**PASTE EXCEL CELLS HERE**"
'.DESELECTALL 'Uncomment to leave the marker text in place (cells are inserted immediately before)
'Replace it with the Excel cells
Sheets("SendMail").Range("A4:J15").Copy 'CHANGE THIS
.Paste
NDoc.PostedDate = Now()
On Error GoTo errorhandler1
NDoc.Send 1, Recipient
Set NSession = Nothing
Set AttachME = Nothing
Set EmbedObj1 = Nothing
Set NDoc = Nothing
errorhandler1:
Set NDoc = Nothing
