เปลี่ยน VBA AUTO Email lotus ไป outlook
choinat
Post by choinat »
ถ้าต้องการเปลี่ยนย้ายโปรแกรมจะต้องแก้ ตรงไหนบ้างครับ
Sub Notes_Email_Excel_Cells()
    Dim NSession As Object
    Dim NDatabase As Object
    Dim NUIWorkSpace As Object
    Dim NDoc As Object
    Dim NUIdoc As Object
    Dim Attachment1 As String
    Dim Attachment2 As String
    Dim AttachME As Object
    Dim EmbedObj1 As Object
    Set NSession = CreateObject("Notes.NotesSession")
    Set NUIWorkSpace = CreateObject("Notes.NotesUIWorkspace")
    Set NDatabase = NSession.GetDatabase("", "")
    If Not NDatabase.IsOpen Then
        NDatabase.OPENMAIL
    'Create a new document
    Set NDoc = NDatabase.CreateDocument
    With NDoc
        .SendTo = Range("P6:P11").Value       'CHANGE THIS
        .CopyTo = Range("P12:P20").Value
        .Subject = Range("P4").Value
        NDoc.SAVEMESSAGEONSEND = True
        Attachment1 = Range("P5")
        Attachment2 = Range("Q5")
        If Attachment1 <> "" Then
        Set AttachME = NDoc.CREATERICHTEXTITEM("attachment1")
        Set EmbedObj1 = AttachME.EMBEDOBJECT(1454, "attachment1", Range("P5"), "") 'Required File Name
       If Attachment2 <> "" Then
        Set AttachME = NDoc.CREATERICHTEXTITEM("attachment2")
        Set EmbedObj1 = AttachME.EMBEDOBJECT(1454, "attachment2", Range("Q5"), "") 'Required File Name
        'Email body text, including marker text which will be replaced by the Excel cells
        .body = Range("B4").Value & vbCr & vbCr & Range("B4:E15").Value
        .Save True, False
    'Edit the just-created document to copy and paste the Excel cells into it
    Set NUIdoc = NUIWorkSpace.EDITDocument(True, NDoc)
    With NUIdoc
        'Find the marker text in the Body item
        .GotoField ("Body")
    '   .FINDSTRING "**PASTE EXCEL CELLS HERE**"
        '.DESELECTALL            'Uncomment to leave the marker text in place (cells are inserted immediately before)
        'Replace it with the Excel cells
        Sheets("SendMail").Range("A4:J15").Copy       'CHANGE THIS
        .Paste
        NDoc.PostedDate = Now()
        On Error GoTo errorhandler1
        NDoc.Send 1, Recipient
        Set NSession = Nothing
        Set AttachME = Nothing
        Set EmbedObj1 = Nothing
        Set NDoc = Nothing
errorhandler1:
    Set NDoc = Nothing
Re: เปลี่ยน VBA AUTO Email lotus ไป outlook
:D ไม่ต้องปรับแต่เขียนขึ้นมาใหม่ ศึกษาจากที่นี่ครับ https://www.rondebruin.nl/win/s1/outlook/mail.htm
