sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Sat Mar 20, 2021 8:19 pm
Hi Dear,
I have data layout a2:b6 I need to sort it by max numbers.i need a formula not built in feature.
I attached a sample with result in color cells
Thanks
Posts: 31255 Joined: Sun Jan 24, 2010 12:33 pm
by snasui » Sat Mar 20, 2021 8:59 pm
Try this,
B12
=LARGE($B$2:$B$6,ROWS(B$12:B12))
Enter > Copy down
A12
=INDEX(A:A,AGGREGATE(15,6,ROW($A$2:$A$6)/($B$2:$B$6=B12),COUNTIF(B$12:B12,B12)))
Enter > Copy down
sna
by sna » Sun Mar 21, 2021 7:11 am
Thanks
but how we don't use helper column?
by snasui » Sun Mar 21, 2021 7:38 am
You can do that with default feature or VBA not a formula.
sna
by sna » Sun Mar 21, 2021 12:44 pm
Ok thank you
by snasui » Sun Mar 21, 2021 1:28 pm
snasui wrote: Sun Mar 21, 2021 7:38 am
The above quote means your result in the same place of the source.
If you need only one formula, can use this formula in A12.
=INDEX(A:A,MOD(AGGREGATE(14,6,$B$2:$B$6+ROW($B$2:$B$6)/1000,ROWS(A$12:A12)),1)*1000)
Enter > Copy to B12 then down.
sna
by sna » Sun Mar 21, 2021 8:51 pm
Thank you so much
