sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Sun May 30, 2021 1:13 pm
Hi Dear!
I have written a macro in form of custom function to average cells base on red color font.
I checked code right but why not calculate right?
Function AverageRed(rng As Range)
Dim C As Range
Dim Count As Long
Dim Result As Double
For Each C In rng
If C.Font.ColorIndex=3 And IsNumeric(C.Value) Then
Result = Result + C.Value
Count = Count + 1
Next
If Count = 0 Then
AverageRed = ""
AverageRed = Result / Count
End Function
What's wrong ,any matter will share file
Best Wishes,
by snasui » Sun May 30, 2021 1:30 pm
Please attach the example Excel file with code above inside.
sna
by sna » Wed Jun 02, 2021 6:17 pm
Here's an attached
the first calculation is right but when change font to black it is not working well
Best Wishes,
by snasui » Wed Jun 02, 2021 7:30 pm
Your attached file is incorrect file type. The extension should be .xlsm instead .xlsx.
Changing the font color does not trigger your formula. Please see this link for more information.
https://stackoverflow.com/questions/563 ... th-changes
sna
by sna » Wed Jun 02, 2021 7:49 pm
Ok thanks for the link
I will take a look
Best Wishes,
sna
by sna » Sat Jun 05, 2021 1:34 pm
File attached
