numbering format
sna
Excel Ver: Excel 365
numbering format
Post by sna »
Hi Dear,
I need your help how to custom format.for example if I input 123 in cell A1 it would become ***123.00***.if i input 123000 in cell A2 it would be ***123,000.00***.
I try "***"#,###.00"***" but I have no luck.
I can format only "***"#,###.00 it would be **123.00,***123,000.00
Best Wishes,
Re: numbering format
:D You can use this format,
"***"#,##0.00"***";"***"-#,##0.00"***"
sna
Post by sna »
Thank you
