insert a row after line 4
sna
Excel Ver: Excel 365
Post by sna »
Hi Dear,
I need a formula or VBA to insert a row after line 4 in a range.
I also attached a sample and output
Thanks
Re: insert a row after line 4
:D The example formula in C2 is:
=IFERROR(IF(MOD(ROWS(C$2:C2),5)=0,"",INDEX(A$2:A$17,ROWS(C$2:C2)-INT((ROWS(E$2:E2)-1)/5))),"")
Enter and copy down.
sna
Post by sna »
Thank you ☺️
